10-01-2012, 07:30 PM | #1 |
Drives: Car Join Date: Sep 2012
Paddle Shifters and drag racing
d
10-01-2012, 07:39 PM | #2 | |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
10-01-2012, 07:41 PM | #3 |
10-01-2012, 07:43 PM | #4 |
Thanks. Can anyone with an automatic respond with how the car behaves in first, stopped with a foot on the brake then immediately putting the accelerator to the floor?
10-01-2012, 07:47 PM | #5 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
If I do that I start out in first gear.
I manually upshift and downshift for fun sometimes. I sit in a lot of traffic so got the auto.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
10-01-2012, 07:51 PM | #6 | |
having FUN now 13.66@101
Sure, you get this. And can do this too.
10-01-2012, 08:00 PM | #7 |
Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
neutral drops are VERY bad..
I don't think the computers on our cars will even allow it.. back in the day it was a good way to spin the driveshaft u-bolts or worse crack the crankshaft. |
10-01-2012, 08:09 PM | #8 |
d
10-01-2012, 08:47 PM | #9 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
You can still do it. No need to though, you'll only spin which can be done with out neutral dropping. What I do is put it in sport, its faster than tapshift, then hold the brake and bring it to 1250rpm and punch it while letting off the brake when its time to go.
10-01-2012, 08:48 PM | #10 | |
small correction.. put into sport. hold the traction control button to take the nannies off (8-10 seconds) then power brake.. |
10-01-2012, 09:02 PM | #11 |
Zach
Drives: 10 SIM 1LT, 66 F100 Join Date: Jul 2012
It takes 8-10 seconds? I hold it for a second or two and it turns off and on.
I like the tapshift, only way I drive my car. 1st gear launches pretty good but as soon as you get into 2nd it gets up to speed pretty quick. My V6 ill hit 50 in 2nd and still only at 4-5k rpms. Plus its fun when your on the highway on 6th drop to 3rd and go
2010 1LT
66 Ford F100 Camaro rep for Az ModRod Productions, havent liked us on Facebook? check it out! http://www.facebook.com/#!/ModRodProductions |
10-01-2012, 09:07 PM | #12 | |
hold it for 8-10 seconds.. it disables everything. each push only disables part of it.. holding it turns all the nannies off (well about 80%, I did a power slide recently and discovered it will still right the car) |
10-01-2012, 09:18 PM | #13 | |
Her Name is Mila
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS Join Date: May 2012
10-01-2012, 09:40 PM | #14 |
Zach
It does for me, I think its just after a certain rpm cause I can go from 3rd to 1st and it jumps to redline. I don't think its the best for the car but what is unless you drive like a senior citizen. I've got a warranty for up to 100k on my car so not to worried about it
2010 1LT
