Old 09-11-2019, 08:11 PM   #1
Conehead396
Drives: 2010 Camaro SS/RS 1967 Camaro RS
Cold Start Smoke
I have a 2011 LTT V6 that sometimes smokes on cold starts. No coolant loss and about 1/2 quart of oil burned in 5000 oil changes.
It is worse after rain, and will do it most mornings, even in warm temperatures so it is not a winter issue.
It always completely goes away after a short drive or if car is left idling long enough. It does not return later in the day, and not smoke under WOT.
If I let car sit till the afternoon before starting it does not do it on a dry day.
I have read a few post and hope it is condensation so I attached a video.
Mileage is 118,00.
There is plenty of water (not coolant) in pipes when this happens.
Also the stock mufflers have been replaced with straight pipes, rest of exhaust is stock.
thanks for any input.
Conehead396 is offline   Reply With Quote
Old 09-11-2019, 08:43 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Most likely just condensation.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 09-13-2019, 02:03 PM   #3
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
Mufflers have small drains to help rid the exhaust of moisture. With straight pipes, any condensation has to be heated to evaporate. A SMALL hole drilled at the lowest point in the exhaust may help but I would not be worried about it.
Levon H. Bone Stock
LevonH is offline   Reply With Quote
Old 09-13-2019, 02:34 PM   #4
G8One2
Drives: 2014 Camaro 2SS
Leaky valve seals will do that
G8One2 is offline   Reply With Quote
Old 09-13-2019, 02:35 PM   #5
G8One2
Old 09-14-2019, 05:27 AM   #6
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
yep...hot exhaust flowing through cold pipes
fhrex is offline   Reply With Quote
Old 09-14-2019, 09:18 AM   #7
Conehead396
Thanks for the feedback. I let the car sit until mid morning today before starting. It is nice and dry outside. No smoke/condensate at all on start up. let it idle maybe 5 minutes and just a very slight amount on passenger side, and exhaust tip was wet by then.
Looks like it is just water after all. Might drill a couple of small hole just to see it that helps. Can always weld them back up.
1967 Camaro RS
383 Stroker
Tremec 3550
2011 2LT
