05-29-2016, 02:24 AM | #1 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Looking for stock Z/28 wheels
I have been looking and looking for a set of stock Z/28 rims. There was one for sale a week ago but they sold quick. Does anyone know where I can find more at? These wheels seem to be very hard to find. I am also not interested in the replicas...I want a 2nd set to run race tires on that will hold up to track abuse. Thanks.
05-30-2016, 03:33 PM | #2 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
http://www.apexraceparts.com/apex-pr...l#.V0yjar7ciUk
05-30-2016, 05:10 PM | #3 |
Drives: Z/28 Join Date: Oct 2015
Nice, You will need a spacer on the front to run those..
05-30-2016, 05:40 PM | #4 |
Drives: Chevys, Fords a Mopar and Ferrari Join Date: Aug 2010
Dang, wish I would have known this.
2015 Z28 #995 - Xpel Stealth Wrapped
Also a car hoarder... |
05-30-2016, 06:38 PM | #5 | |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
05-30-2016, 07:11 PM | #6 | |
Drives: 2014 Camaro Z/28 Join Date: May 2016
05-30-2016, 08:14 PM | #7 | |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
Not sure why you would need a spacer like mentioned above. The offset should make them work fine. Sent from my XT1585 using Tapatalk
05-30-2016, 08:46 PM | #8 |
The stock front is a 19x11 11mm offset, the wheel mentioned above is a 19x11 25 offset so moving the wheel inwards 14mm, I dont thing there is 14mm clearance from the inside of the rim to the strut (depending on how much - camber is set at the spindle) I think with 0° camber there is around 10mm clearance, with factory - camber maxed out there is only 5mm clearance. A 10mm / 15mm (depending on camber and tire used ) spacer would be required in the front only.
05-30-2016, 09:43 PM | #9 |
Ya the OP was asking about OE Z/28 wheels. Not sure why the other posted those Apex wheels
05-30-2016, 10:14 PM | #10 |
Lover of Speed
I went to the dealer and the price was way too high for me to want to jump on initially. It was close to like 1500 a wheel, plus a 100 core charge. If someone knows a dealer with better prices I am all in.
05-30-2016, 10:16 PM | #11 | |
Lover of Speed
05-31-2016, 06:30 AM | #12 |
Try searching part numbers online. I thought these wheels were closer to $700-800 each. Try Pace Performance.
05-31-2016, 06:44 AM | #13 |
Drives: '21 ZLE A10 Join Date: May 2012
$680ish is just about the best price I have seen others mention
05-31-2016, 07:15 AM | #14 | |
68, 69 & 2015 Z/28's
68 Z/28 Restoration Thread on Team Camaro http://www.camaros.net/forums/showthread.php?t=182584 |
