05-30-2016, 07:40 PM | #1 |
Drives: 2015 Z28 + Piper Comanche Join Date: Nov 2015
Water deflector removal?
Going to the track Friday. Would like to remove the water deflector that is mentioned in the track prep.
http://www.chevrolet.com/content/dam...PREP_Final.pdf Ok I'm confused. What part is it? Picture? Thanks |
05-30-2016, 08:14 PM | #2 |
Drives: Z/28 Join Date: Oct 2015
Open your hood and look straight ahead. Big black plastic element in the center.
05-30-2016, 08:58 PM | #3 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I removed mine within a couple months of owning my 1LE (same vent as Z/28). I have had zero problems with this removed. I have been in heavy, driving rain, GM's WeatherPak electrical connectors are bulletproof.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
05-30-2016, 09:00 PM | #4 |
Drives: 1969 Z/28 + 2015 Z/28 Join Date: Aug 2009
There are I think 7 plastic fasteners that need removed. They have center pins that you pull out some that releases the whole fastener for removal. I'm sure there is a tool for doing it but I used two small flat blade screw drivers. There is a trick to doing it this way but forget what it is.
Also, you need to reinstall one or two of them that holds the seal for the air intake. The first one is the hardest, not wanting to break one. Once you see how it works the rest were easy. Good Luck!
You know you are having fun when you are getting 3.4 mpg !!
05-30-2016, 09:17 PM | #5 | |
Popped the plastic "rivets" out. Can start them with a screwdriver. All came out east. A few went back in to hold the cold air induction plastic that is on the underside of the hood. Thanks. Last edited by Hunt-man; 05-30-2016 at 09:44 PM. |
