Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-27-2019, 03:43 PM   #1
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
Metal Caps on Valve Steams
When I got my BFG Comp 2 A/S installed by Discount tire, they seemed to think that I should use the black plastic valve stem caps that they provide and not the metal ones that came om my car originally. Why do you suppose that is?
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 07-27-2019, 04:40 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Cheap metal caps can corrode and become impossible to remove.
Since we have TPMS they are rarely removed to check the pressure.
Put a drop of oil or dab of light grease on the threads if you are concerned.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 07-28-2019, 04:44 PM   #3
Coop[580
Coop[580's Avatar
Drives: 2012 ZL1 Ashen Grey
Get the ZL1 caps. Cheap good looking “mod”.
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam
Tuned and built by Speed Inc
635/632-93 octane
725/738-E85
Coop[580 is offline   Reply With Quote
Old 07-29-2019, 10:42 AM   #4
2013ZL1FUN
2013ZL1FUN's Avatar
Do you have a picture of the ZL1 caps? I've never heard of them. Where can you get them?
OHIO
Old 07-29-2019, 10:45 AM   #5
2013ZL1FUN
2013ZL1FUN's Avatar
Wink
I wasn't concerned at all CamaoFred, discount tire was concerned!
OHIO
Old 07-30-2019, 11:47 AM   #6
Trickskier
Native Floridian
Trickskier's Avatar
Drives: 2014 - ZL1 / 1986 IROC-Z
Here ya go - Link below:
https://www.phastekperformance.com/s...m+caps&Submit=
Old 08-02-2019, 10:12 PM   #7
Coop[580
Coop[580's Avatar
Mine are black plastic. Not sure where I got them.
2012 M6
635/632-93 octane
725/738-E85
Old 08-03-2019, 09:04 AM   #8
Ducatiman
Drives: 2015 2SS/1LE
I am going to throw another thought out there. I got my 1LE back from the local Costco tire shop with brand new Michelins installed. All good, except later noticed my factory metal valve stem caps had been replaced with plastic ones. I immediately returned to the shop and the tech had all four of them stashed in his toolbox. These guys change tires for a living. They know the good stuff from the cheap stuff. Your factory 1LE metal valve stem caps are not cheap. Go down and order one and you will see. They are a higher quality than any I've seen and tire techs know it. Watch your valve stem caps guys, people want them.....
Ducatiman is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
