Emblempros
Old 07-29-2019, 08:17 PM   #1
Busa317
Drives: 2010 camaro ss
Ecs novi 1500
Hey guys I have a 2010 ss with a ecs novi 1500 supercharger kit on it long story short i feel the car is not performing how it should its a l99 auto and has full exhaust does a 12.20 @113 sound right and this is with race star wheels front and rear with skinnies on the front and mt drag radials on the rear i know these cars are on the heavier side but i still think the car should be a little quicker ,does this seem normal or maybe there is a problem everything else is stock on the car besides supercharger and exhaust
Busa317 is offline   Reply With Quote
Old 07-30-2019, 04:10 AM   #2
Slickcas
Drives: 12' 2SS/RS LS3 IBM
It’s a little slow. If you have the stock fuel pump and injections that’s a big factor. Tuner may have it way turned down. Also ECS likes to spin the supper charger fast and use a restrictive plat in the inlet.
Will need a ZL1 pump and tune the FPCM. Set of fuel injectors. I have a set from my Vortech Kit. Also do you have the ZR1 3 bar map sensor?
Slickcas is online now   Reply With Quote
Old 07-30-2019, 05:31 AM   #3
Busa317
I have 60lbs injectors not sure about the pump i just got the car and the kit was already on it
Old 07-30-2019, 05:44 PM   #4
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
Most likely the stock and a bap....any other mods on it?
ZL1 10 spokes,LS3 Conversion,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 07-30-2019, 06:53 PM   #5
Busa317
It has kooks headers high flow cats borla mufflers and the ecs kit boost guage is not working so im not sure where it is it seems pretty low im going to go through the car but like I said i took it as is and just feel like it should def be quicker the car is hooking pretty good consistant low 1.80 60ft
Old 07-31-2019, 01:04 PM   #6
mrimpala02
Drives: Black 2SS RS w/White Stripes
Need to datalog it and check how the tune is doing.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 07-31-2019, 02:54 PM   #7
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Tune
You have way to log or post tune
1fast is offline   Reply With Quote
Old 07-31-2019, 06:27 PM   #8
gm2376
gm2376's Avatar
What does your boost guage read? I think the stock boost is 7 or 8psi on the stock pulley.
Old 07-31-2019, 07:57 PM   #9
Busa317
Just got the car it has 4 guages the most important ones are not working (boost and air fuel) i will be replacing them asap
Old 07-31-2019, 08:06 PM   #10
Busa317
And no way to data log
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
