08-02-2019, 07:48 PM | #1 |
Drives: '17Raptor,'68Firebird,'18MacanGTS Join Date: Nov 2011
Break bedding procedure
Hey can anyone remember what part of the 1LE manual or performance supplemental manual the break bedding procedure is in? I cannot find it anywhere. I know I saw it ... somewhere.
08-02-2019, 07:58 PM | #2 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
break what ?
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
08-02-2019, 08:00 PM | #3 |
Drives: '18 RH ZL1 1LE Join Date: Apr 2018
meh, just brake progressively harder and harder with a little time for them to cool off in between..you should be smelling them during the last few of the hardest stops. That should be fine. The idea is to get as much pad material on the rotor without 'shocking' them, if that makes sense.
08-02-2019, 09:04 PM | #4 |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
lol I tried bedding them per the procedure (which is insanely long IMO) but frankly just couldn't get enough heat into the suckers on the street. First track day I'm pretty sure they were bedded after the first session.
08-02-2019, 09:14 PM | #5 |
I've done 2 sets at trackdays..Charlotte Roval both times oddly enough, 1st session is more than enough
08-03-2019, 11:51 AM | #6 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
See the brake bedding/burnishing procedure here:
https://www.camaro6.com/forums/showp...22&postcount=5 |
08-04-2019, 08:31 AM | #7 |
Drives: gas powered Join Date: Jan 2019
08-04-2019, 11:43 AM | #8 |
Drives: 2018 ZLE, 2023 C8, IMSA MX-5 Join Date: Jul 2019
Have done at track (COTA and RA) on 2 separate ZLE's. You will definitely smell them. Likely get soft pedal feel during laps 3-5 so be prepared. I usually back off a lap and they progressively firm up.
08-06-2019, 08:16 PM | #9 |
Just make sure you keep your foot off the brake after bedding until they cool down!
08-06-2019, 10:02 PM | #10 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I personally think that the bedding procedure that GM publishes is excessive. Less than 1/3rd of that is necessary.
08-06-2019, 10:58 PM | #11 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
Buy pads from Carbotech and they bed them for an extra $20. Install and ready to drive.
