Old 09-20-2019, 12:56 AM   #1
MNCamaroGuy
MNCamaroGuy's Avatar
Drives: 2011 Chevy Camaro 2SS 6spd
Forged bottom end - what do I need?
Hello all,
I'm new to the world of forced induction and I just bought a Huron single turbo kit with a Precision P7675 Gen2 cea. I'm hoping for 850+ whp at 15-20 psi.
From what I've read and understand it's worthwhile to invest in a forged bottom end for longevity and reliability but I'm not really sure what specs I should go with as it's all new to me. Maybe I should go with a stroker setup?
The main thing I need is to know what sort of specs (bore, stroke, rod length, etc) I should be going for.
Any recommendations on brands, types of setups and or any other various advice is much appreciated too.
Current setup:
Stock LS3 block and bottom end
Melling high volume oil pump
TSP stage 3 3-bolt camshaft for forced induction
Billet rollmaster timing gear and chain
LS7 lifters
Hardened pushrods
Upgraded rocker arm trunions
Ported LS3 heads with springs rated to 0.660" lift
Everything else is either irrelevant or coming off with the addition of the turbo
Thanks for reading.
Last edited by MNCamaroGuy; 09-20-2019 at 01:41 AM. Reason: Forgot to add engine details
MNCamaroGuy is offline   Reply With Quote
Old 09-20-2019, 04:12 AM   #2
bayarea408
bayarea408's Avatar
Drives: 10' 2SS RS L99
i'd buy a tsp or equivalent forged gen 4 short block, iron holds more power 100lb's more in the front of the car. They have resleeved aluminum stuff but that gets pricey. I would do a 6.0 stock bore stroke forged lq4/9, sell the sbe ls3 short block, use the ls3 heads you have already some work in....this is actually what i want to do LOL!
2010 2SS/RS -Huron Single Turbo Precision 76/75 cea
bayarea408 is offline   Reply With Quote
Old 09-20-2019, 12:16 PM   #3
hillshooter
Drives: 2015 Camaro SS commemorative
Go with a thompson shortblock. I had a tsp and unless you have a popular youtube channel their customer service is the worst.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 09-20-2019, 12:17 PM   #4
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Look up https://www.stevemorrisengines.com/2...s-build-videos for some of what it takes....
For what you are doing you could just go with rods and pistons from Tick.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 09-20-2019, 02:11 PM   #5
graf101
KING_1LE
graf101's Avatar
Drives: 15' RRM/2SS/1LE
x2 for a Thompson shortblock. I have a Thompson Dart 388 iron block on standby for mine.
graf101 is offline   Reply With Quote
Old 09-21-2019, 04:25 PM   #6
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
I doubt you'll make 850 with the single kit. The downpipe will be the limiting factor.
Currently in the fleet... 2017 Corvette ZO6, 2010 Camaro SS Huron Speed Twin Turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 09-25-2019, 06:39 AM   #7
eLeSthree
Drives: 2011 Camaro SS 6sp
or if you're on a budget, just buy a good set of pistons and rods. Use the stock block and crank. Take it all to your local machine shop for balancing. Should be good for 1000whp. Lots of people doing that.
TMS Dart 427 FED M311s, TMS cam, ESS Tuning G3X Blower, DSX Tuning Triples and FF, FIC1300, Mcleod RXT 1200HD, JRE Tuned 935/856 16.5psi... G4 coming soon.
eLeSthree is offline   Reply With Quote
Old 09-25-2019, 09:32 AM   #8
Russell James
Russell James's Avatar
15-20 lbs is a huge range. When you get up into pressures in the teens and above, every lb boost increase is next level engine foundation strength needed.
Example.... look at OE engines with R&D behind them. What does it take to make a B15 crate engine survive validation testing at 15 lbs of boost... iron LSX block, 6 bolt heads, 8 bolt crank flange, priority main oiling.... That's over and above just "forged bottom end". What would it take to survive 20 Lbs... ? the next level, in my opinion. Aftermarket block, monster head studs, and a builder that's done it successfully before.
If you are just considering "forged bottom end" ... and not going 6 head bolt iron block, big head studs, priority main oiling... I'd reconsider that lofty goal of 15-20 lbs. maybe more down toward the lower teens.
People are doing it, and will it last are two different things. Stock head bolts, small dia head studs can only take so much boost before the heads start lifting. Someone that can make a couple passes with huge boost is different from several hundred passes with minimal maintenance.
1000 crank hp on a stock block, stock heads? Might make a few passes.
Old 09-25-2019, 09:52 AM   #9
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Originally Posted by MNCamaroGuy View Post
Hello all,
Current setup:
LS7 lifters
Hardened pushrods
Thanks for reading.
Eagle or Scat.
ZEN357 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
