05-03-2018, 09:54 AM | #1 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Why did the 6th gen SS 1LE get wider tires at the rear only?
Given that the 5th gen 1LE and Z/28 both ran same-size tires at all four corners, I'm wondering what changed the philosophy specifically for the 6th gen SS 1LE away from maintaining the same tire size all around and simply making the rear wheels a little wider than the fronts.
Was it a downstream consequence of the bump in power and torque? Understeer budget or breakaway characteristics reasons and the Alpha chassis? Appearance? Other? Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
05-03-2018, 10:49 AM | #2 |
Drives: 2018 Camaro SS 1LE Join Date: Mar 2018
Fitting 20" 305s all the way around is not possible without modifying fenders up front. Even the ZL1 1LE has wider front fenders, 19" wheels & narrower front suspension to fit 305s upfront.
05-03-2018, 11:15 AM | #3 |
The question is really about why they widened the rear tires at all, if they were going to leave the fronts alone.
Norm
05-03-2018, 11:25 AM | #4 |
Moderator.ca
Presumably because it still offers more overall grip than not putting wider tires out back.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
05-03-2018, 11:40 AM | #5 |
The fronts haven't been left alone. The standard SS gets 20x8.5" 245mm tires up front. The 1LE has 20x10" 285mm up front. So front grip has been upgraded and tuned to match the rear end grip.
05-03-2018, 11:46 AM | #6 | |
Drives: 16' 2SS, 06' Silverado SS Join Date: Jul 2017
if you notice on drag cars or slicks how the tires are really wide on the back.. same situation. larger surface = better grip overall, especially on a launch. more hp and torque means less grip for rwd cars. |
05-03-2018, 11:47 AM | #7 | |
Norm
05-03-2018, 11:49 AM | #8 | |
Norm
05-03-2018, 11:53 AM | #9 | |
What I'm looking at here is strictly the cornering & handling side. Straight line stuff at the SS level is a mission for the non-1LE SS with A10. If Chevy is trying to squeeze a bit more straight line capability into these cars that are primarily not about the straight line, that would fall under the "other" catch-all. Norm
05-03-2018, 12:07 PM | #10 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Given how snug the fitment is with the 285's in non-ZL1 fenders, to me that's likely the primary limitation.
2017 "M1SS1LE" in Hyper Blue w/PDR
05-03-2018, 01:26 PM | #11 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
This question was asked to Al during the last Camaro Fest in Bowling Green. He said that they tested several different options, including a square setup like the 5th gen SS 1LE, and they were able to get faster lap times and overall better handling characteristics with the setup they chose. The practical benefits of the square setup were offset by the better performance characteristics of the staggered setup.
Keep in mind that the 6th gen suspension geometry and chassis are different from the 5th gen, so what worked well on one may not work well on the other.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
05-03-2018, 01:33 PM | #12 | ||
Plus you also want to run a tire as narrow as possible for your traction/handling requirements. As wider tires add friction, drag & weight. Reason like that is why you don't see F1/Indy cars running a square stance. |
05-03-2018, 02:12 PM | #13 |
Hot Dog
No, F1 cars don't run square because their rules disallow it. It's an entirely different topic.
05-03-2018, 02:20 PM | #14 | |
Drives: 2018 2SS Coupe A8 Join Date: Nov 2016
Interesring question
