05-24-2018, 09:27 PM | #1 |
Drives: 2018 Camaro V6 Join Date: May 2018
2018 Camaro V6 5k miles needs new cat?
So I’ve had the car about 3-4 months. Had a check engine light come on and dealer installed a new o2 sensor. Got the car back and after about 30 miles the light came back on again. Took it back in and dealer said they called Detroit and they advised them to swap out the cat. Just got it back today so we shall see. Should I be worried? I've been reading that cats should last lifetime of the car and if they fail it’s a underlying problem. Any opinions?
05-24-2018, 09:38 PM | #2 |
You've got a warranty if you need it but it seems like a odd issue for sure. I wonder what code popped up. Without the code its hard to say.
05-24-2018, 10:00 PM | #3 |
Drives: 2015 Camaro SS Join Date: May 2018
Yeah hopefully they can figure out what’s wrong. Your Cat shouldn’t be out already.
2015 Camaro SS (1ss w/ RS Package - L99 Engine) - Former Pace Car - Marysville, WA
Instagram: www.instagram.com/426andcounting Use discount code 426andcounting on http://www.devoteesofficial.com for 15% off your order! |
05-25-2018, 12:11 PM | #4 |
Drives: 2013 ZL1 Join Date: Dec 2012
That's what the warranty is for
'13 ZL1
'06 TBSS '98 TJ '87 GN |
05-25-2018, 12:21 PM | #5 |
Its probably not the cat and the light will be back on in a day.
2010 Camaro 2SS/RS
05-25-2018, 12:36 PM | #6 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Emissions warranty is 7 years.
So you don't need to worry about out of pocket until 2025.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
05-25-2018, 01:06 PM | #7 |
Drives: 2011 Camaro 2SS Join Date: May 2016
good thing its New! keep an eye on ANYTHING out of the ordinary when driving, if anything at all happens, take it in, get them to check it, see if they can find the underlying problem
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
05-25-2018, 05:35 PM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Sometimes things just happen. I wouldn't worry. It is a process of elimination diagnosing modern automobiles. Have patience
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-26-2018, 10:29 AM | #9 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
I couldn't disagree more. I find it's harder to diagnose a car that isn't computerized. The computers take 100% of the guess work out of it for me. It allows me to concentrate my diagnosis on a specific area of the vehicle. He had a hasty diagnosis.
05-26-2018, 10:48 PM | #10 |
Drives: 2011 Camaro 2LT/RS Join Date: Sep 2011
If your codes are a P0420 or 430, then its possible you could have bad gas throwing a lot of carbon on your O2 sensors. Run some Seafoam in your next tank of gas and fill up with Premium.
02-11-2020, 09:15 AM | #11 |
Drives: 2019 Camaro 1LT RS V6 Join Date: Mar 2019
I have a 2019 Camaro V6 RS with only 10k miles and also got a P0420. They will be installing a new cat next week, but I too am concerned about an underlying problem.
What questions should I be asking? morenm01, did your ever come back again? |
02-11-2020, 09:58 AM | #12 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
My cat was replaced under warranty due to cracks. Diagnosis was road damage.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
