Old 10-10-2013, 04:29 PM   #71
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Originally Posted by Mikamaro View Post
Installed
Front Springs: Yes
Front Dampers: Yes
Front 27mm Bar & links: Yes
Front Mounts (New Rev): Yes
Rear Upper Mounts: Yes
Rear Dampers: Yes
Rear Springs: No (kept oem Fe3)
Rear 28mm Bar & links: Yes
Rear Sub-frame bushings: NO
Rear Toe Links: Yes
Rear Lower Control Arms: No
275/40/20s all round on Oem 9in rims: Yes
I gather a hole was drilled to mount the 1LE droplinks for the rear sway bar in your FE3 RLCAs?
Old 10-10-2013, 04:50 PM   #72
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Time to post my best lap at my local track: ICAR
I spend almost every second tuesday afternoon there lapping.
So managed a 1:50.6 with the 1LE track pack, that's 3.3sec off my best time with the Stock 2010 SS Suspension.
Also pulled the highest peak lateral G: -1.57
Peak Brake G: -1.25
Peak Accel G: 1.05
Next year lightweight Rims and 305/19 rubbers, like the Z/28.
tramtwo is offline   Reply With Quote
Old 10-10-2013, 05:06 PM   #73
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
I would assume so, otherwise how could he have install it...??
I will have to verify that with my mechanic.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 10-10-2013, 05:17 PM   #74
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Yes. Confirmed
Old 10-10-2013, 05:19 PM   #75
JusticePete
The ZL1 / 1LE RLCA has a reinforcement (large 'washer') welded around the hole to prevent flexing in the arm. It may be wise to do the same to your RLCAs. Flex at the attachment points would create a changing load from the bar resulting in uneven action.
Old 10-10-2013, 06:25 PM   #76
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Originally Posted by JusticePete;70824Fl2
*Flex at the attachment points would create a changing load from the bar resulting in uneven action.
Yes. Exactly! It's very minimal but on the track I feel it and makes it lightly unpredictable.
Okay. So I will get the Fe4/5 LCA and replace them.
I will report back.
Anything else?
Old 10-10-2013, 06:42 PM   #77
JusticePete
I will report back.
Anything else?
Sub-Frame bushings, Z style arms and tweak your alignment to put an end to snap oversteer.
Front Camber: -1.66
Front Toe Total: -0.2
Rear Camber: -0.78
Rear Toe Total IN 0.20
I do have a preference for our sub-frame bushings. Total Control Area in our EP1201 bushings is multiples greater than OEM FE3 / 4 / 5 / 6.
Old 10-10-2013, 10:18 PM   #78
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Pete are you saying that the subframe bushings are different on the 1LE than a stock FE6 SS?
Sent from my DROID RAZR using Tapatalk 2
Old 10-11-2013, 07:20 AM   #79
JusticePete
Unless the sub-frame bushes are green like those in the picture below the answer is yes.
Old 03-05-2014, 04:55 PM   #80
Purpleanga
Drives: Grey LS
I've got the stock suspension on my 13 camaro v6. I want to make it feel a bit tighter in handling and corners. Should I got for this track pack or just install a simple strut bar on the front axel? Also does this kit lower the car at all?
Purpleanga is offline   Reply With Quote
Old 03-06-2014, 05:30 AM   #81
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
When I got my kit we made sure we got the one with the subframe bushings. Makes a world of difference, but also upped the install price since dropping the entire cradle.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-06-2014, 10:16 AM   #82
JusticePete
1LE Kit Advantages
1. Better damping / valving / Struts
2. Rear Sub-frame bushes
3. Rear Toe Links
4. Rear upper mounts
Plus / Minus
The 1LE sway bars are designed for a square wheel and tire setup. The SS delivers with a staggered wheel and tire setup. Match the sway bars to your tires and wheels. If you have staggered buy the factory ZL1 bars. If you have 1LE / Z/28 square setup buy the ZL1 bars. That is not a typo. The 27mm front 1LE bar understeers more than the 25mm front bar ZL1 setup.
Old 03-06-2014, 10:21 AM   #83
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
1LE Kit Advantages
3. Rear Toe Links
Plus / Minus
Reading this, are yo saying that if you have a 1LE, yo can further reduce the understeer by changing the stock 1LE front sway to the smaller 25 mm sway? also, can you explain to me why that would be the case. I am new to the whole suspension deal.
gajagfan is offline   Reply With Quote
Old 03-06-2014, 10:43 AM   #84
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
It is a black art!
Reducing the size of the front sway bar would increase front grip....BUT with the stock rate front springs couldn't the cause-effect be the inside rear wheel would "lift" decreaseing traction on corner exist when trying to apply power?
HMMM got me thinking here!
-Matt
