Old 09-07-2018, 08:42 AM   #1
d454brisson
Drives: 2014 ZL1
Puller
This little guy and its brother have paid for themselves
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I was able to remove a stock pulley with zero damage grabbing the last portion on the outside.
It also just pulled my damaged metco hub off like butter, no deflection or popping off. I did use a radiator clamp to hold the fingers closed to start it off.
Best 50$ I ever spent
d454brisson is offline   Reply With Quote
Old 09-07-2018, 10:31 AM   #2
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Your upper or lower?
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you donít forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 09-07-2018, 11:33 AM   #3
d454brisson
Drives: 2014 ZL1
Upper, there is a specific stock harmonic balancer puller
Old 09-12-2018, 09:34 AM   #4
EvilZL1
Snake Eater
EvilZL1's Avatar
Interesting, I wonder if there is a tool to press the 2.5 pulley on without having to take the blower somewhere to get it pressed on
Old 09-12-2018, 03:16 PM   #5
d454brisson
Drives: 2014 ZL1
So I was able to isolate the shaft, heat the new hubs both lingenfelter and metco and using drifts basically hammer them on with the snout removed. Not as sexy as a press but if you keep everything straight, and use a socket to go around the center of the bllower side of the shaft it works well
DB
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
