01-06-2014, 10:45 PM | #1 |
Whipped
Stock rear SS rims fit on front?
Will the stock rear wheels fit on the front with no rubbing? If so, how much rubber could I stick on the rims with no rub issues?
01-06-2014, 11:46 PM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Yes. 275s are really it, and the 20x9s are the minimum size
01-06-2014, 11:50 PM | #3 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
I run the 20x9's on 275-40-20's all around with no problem. The square setup is how the car should have come from the factory for rotational, load and handling purposes.
I would not run anything wider than a 275 on the stock 20x9's. You may want to consider 275-35-20's for a slightly lower profile. |
01-06-2014, 11:53 PM | #4 |
I was thinking of doing this setup myself. Is there any noticable offset between front and back?
01-07-2014, 06:11 AM | #5 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
YES, there are a TON of us that running the stock 20x9's and 275/40's on all 4 corners.....I have been running it for about 1-1/2 years now. no issues at all, and the car actually handles better this way.
01-07-2014, 06:33 AM | #6 |
Drives: '12SS/2SS/45TH-'06 2500HD/Silverado Join Date: Jul 2012
I want to do that too. Is it a real noticeable improvement? Does it increase the chance for rock chips behind the front wheel, or is that just a 50/50 chance anyway?
01-07-2014, 06:37 AM | #7 | |
Let's go Rangers!
It will increase the chance of rock chips on the rear gills. Sent from my AGM, 2SS/RS |
01-07-2014, 07:17 AM | #8 |
SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
Yes they will fit with no rubbing, I dont have stock wheels but I run 20x9s on the front with 275/40/20 tires
01-07-2014, 06:33 PM | #9 |
Whipped
I'm just looking to do this for the track. I like my forgestar rims. Going to us my stock rims for track tires.
01-09-2014, 10:57 PM | #10 |
What tires do all of you like to put on this square setup?
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars] |
01-10-2014, 04:04 AM | #11 |
I'm running Invos. Think about a 275-35-20.
