Old 12-12-2018, 06:39 AM   #1
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
Any of you familiar with this IC pump?
Got this as part of my LSA kit, although I can't find any specs on it or anyone on here who has actually used it. It looks a lot like the OEM ZL1 pump, although it appears to be for the Chevy Volt and Caddy CT6. Just making sure I wasn't sent the wrong pump by accident.
Part# 13597899
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 12-13-2018, 01:59 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
No experience with that particular pump. GM lists it as a "high flow' pump though. Check out the parent manufacturers website:
https://www.buehlermotor.com/en/prod...ric-pumps.html
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 12-13-2018, 02:13 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
That is the zl1 ic pump (same as volt) and is pwm controlled. Should have wiring details with the kit. These are designed to come on when a certain temp is reached. I believe they can be set to run all the time. I have the Varimax pumps on mine (duals) on all the time... So I'm not using the zl1 version..
-Don
747 RWHP 794 RWTQ
Old 12-13-2018, 02:41 PM   #4
J Rod
J Rod's Avatar
Ok cool (pun intended)... definitely an upgrade over the Bosch then. Thanks fellas
