JDP Motorsports
Old 04-18-2018, 08:50 AM   #1
Gotit4cheap16
Drives: Victory Red
Dsx aux fuel pump Kit fuel pressure
So I have the dsx kit installed and tuned for E85. Yesterday while roll racing a friend, I still see my fuel pressure at the rails through my aeroforce gauge drop down to 43psi at wot. Why would this be?
Gotit4cheap16 is offline   Reply With Quote
Old 04-18-2018, 08:58 AM   #2
DSX Tuning
Drives: 2018 Colorado ZR2/2019 Corvette ZR1
Use something other than the Aeroforce to check pressure. I've seen many instances of the Aeroforce reporting pressure incorrectly when it's high.
St. Louis, MO
314-396-7333 --- dave@dsxtuning.com
Flex Fuel - Fuel Pumps - Harnesses - Tuning - R&D
DSX Tuning is offline   Reply With Quote
Old 04-18-2018, 10:47 AM   #3
Gotit4cheap16
Drives: Victory Red
OK thank you. Would a manual fuel pressure gauge work?
Old 04-18-2018, 03:34 PM   #4
ecreps
Drives: 2014 1LE, 1996 z28
If you have HP tuners it should be logged there.
ecreps is offline   Reply With Quote
Old 04-19-2018, 01:03 AM   #5
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Are you using the stock SS FPCM tune? If so it’s doing exactly what it’s told and dropping pressure higher rpm’s.
Slickcas is offline   Reply With Quote
