08-26-2014, 11:11 PM | #71 |
Booooosted.
After the tune I'll check out the electric pump or other.
08-26-2014, 11:11 PM | #72 |
Booooosted.
There are 4 vac lines. Rear barb for the BAP, brake booster, PCV and evap.
08-27-2014, 06:33 AM | #73 |
Drives: Love the one you're with Join Date: Sep 2009
You have a maggie right? Is the bypass opening all the way with no throttle Input? you could remove the rear blower belt, start the car and idol only to see if the vacuum is higher without the supercharger. If not, I would say it's the type of cam you have if you have no other vacuum leaks.
08-27-2014, 08:00 AM | #74 | |
Geek
What you're describing is essentially what CFD and I were talking about. On my car when I jump from reverse to going forward... I disconnect the driveline with the clutch. Mine doesn't need as much timing because it's unloaded. Yours still has to push some load. At least this is what we were theorizing haha. Like I said.. I haven't ever hooked up to an auto car and looked at the tune differences.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
08-27-2014, 08:12 AM | #75 | |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
08-27-2014, 08:20 AM | #76 |
Geek
Mine still looks pretty wild at idle, but you can see it start to level out as soon as I touch the gas pedal. My transition from reverse to drive out of the driveway is between the two humps at the end of this screenshot. It still dips way down, but mine never stalls. You guys might just need to tighten it up a little down there.
08-27-2014, 08:37 AM | #77 | |
The similarities between mine and PQ's is what makes me think it's in his tune especially where he has gone through most of the mechanical possibilities. |
08-27-2014, 08:49 AM | #78 |
Geek
Turn off spark smoothing if you haven't already. That did wonders for eliminating the crazy swings in timing under normal driving.
08-27-2014, 08:53 AM | #79 |
08-27-2014, 10:49 AM | #80 |
Drives: Camaro Justice Join Date: Jun 2007
You have a maggie, correct?
08-27-2014, 12:04 PM | #81 |
Geek
I would suspect the same. Ryan is the one that told me to do it when I was fighting timing swings and bucking. He helped me out a lot learning how to tune this thing. Him and Michael Hornback from Straightline Performance. Invaluable!
08-27-2014, 12:22 PM | #82 |
Drives: the 2nd amendment home Join Date: May 2008
Pete, he has a Maggie, and with the pulley changes he's spinning the turbines a bit quicker even at idle.
Maybe try a little carb cleaner spritzes around the intake gasket. (I just had a feeling of deja vue) ... got exhaust leak?
-- Benjamin Franklin |
08-27-2014, 12:26 PM | #83 |
1. Bypass the Maggie supplied catch can. They are prone to vacuum leaks. Does it improve?
2. Spray it. No NOS. Carb Cleaner. With the engine at idle, spray the carb cleaner all around the mounting / gasketed areas. if there is a leak you'll see an immediate change in idle when you spray it. |
08-27-2014, 06:18 PM | #84 | |||||
Booooosted.
Could be this cam with a stock TC and the 1800 stall? Those pulleys are a bitch while installed. I do have a small serpentine I can possible put on bypassing the front drive pulley of the blower. Quote:
So tune, leak, cam caused, or overdrive pulley caused. Quote:
I'll try the carb cleaner instead of the propane. |
