Old 10-05-2019, 05:49 PM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Dyno over 500rwhp cam only
Did 540rwhp /425rwtq uncorrected
519rwhp / 407rwtq corrected, HP were still climbing at 7300.
Cam is holding on but clearly I need something bigger.
91oct.
On a dyno mustang but it was calibrated to dynojet results.
TSP 231 236, Tick perf PR/ 660 springs, SW headers 2" & HFC, NPP, Goertz1 custom intake to fit hood, U/D pulley, 18lbs spec clutch, vararam Cai, Pat G tune.
I trapped 123.6 on a 2.0 0-60ft 4000 RW.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 10-05-2019, 05:50 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
nice. whats ur combo.
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 10-05-2019, 06:00 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I too am cam shopping. Trying to decide between a cam motion llsr and a btr spec hyd cam....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-05-2019, 06:05 PM   #4
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
With an LOD I'd go llsr.. I think my similar intake is easily good to 7800-8000
13' 1LE
Old 10-05-2019, 07:37 PM   #5
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Got slips, Whammo?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 10-05-2019, 07:39 PM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by Chris49066SS View Post
Got slips, Whammo?
You can check for my post in the 1/4 mile list for my best ET 11.90@122. did 11.99@123.6 that day. Couldn't do better than 2.0 0-60ft.
13' 1LE
Old 10-05-2019, 07:52 PM   #7
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Is that 60 foot with the toyos?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 10-05-2019, 08:04 PM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Yes. Only the slick equipped car did well that day. Toyo DR just aren't cutting it. Gonna go with Mickey next year.
13' 1LE
Old 10-06-2019, 10:04 AM   #9
Chris49066SS
Drives: 2010 SS L99
Solid trap speed! It will definitely be interesting to see how the stickier tires help you
Old 10-06-2019, 10:11 AM   #10
Umbriel
Drives: 2016 Camaro SS
I went 11.2 @ 122 mph cam only with a 1.5 60 foot. 492 rwhp Dyno
Sent from my SM-G955U using Tapatalk
Umbriel is offline   Reply With Quote
Old 10-06-2019, 10:19 AM   #11
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I wanna see that intake! Solid cam only power right there. Hoping to go some 11.5x times on my next trip out. It was on a pass to easily do it last time I was out, before my night was cut short by coolant all over the track.
I think you should go some mid-low 11's on that kind of power with a good tire. Those light weight clutch setups are no joke and really seem to make HP and MPH good!
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 10-06-2019, 12:26 PM   #12
Chris49066SS
Drives: 2010 SS L99
Thats what I am shooting for next month. 11.32@120mph right now but I think with cooler temps and better DA 11.2 should happen. 11.1 is asking a bit much
Old 10-06-2019, 12:44 PM   #13
Umbriel
I feel like with better weather I could have maybe gotten an 11.1 but don't think it would get any quicker at 122 mph. Now I've got a forged 416 stroker, GPI boost cam, fuel system, F1-A Procharger, Procharger intake, DSS driveshaft GeForce 1400 HP axles. Hoping to go mid to low 9s with it.
Old 10-06-2019, 01:42 PM   #14
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Well I was at the track and rain again. I think I got cancelled like half the time I went to a track :(
That's a solid setup!! I'm hoping for 11.6 until I buy Mickeys
Thanks! DA was good in the 800 but not hero DA.
13' 1LE
