10-11-2020, 08:22 PM | #1 |
Drives: 2011 Chevy Camaro LS Join Date: May 2016
Overheating!
My car keeps going to 258 when I’m driving but it drops to 212 210 whenever I stop.
I got the message on my dashboard about my car overheating , I couldn’t pull anywhere to the side ,but when I was about to,the needle went back to normal. The fans are working properly. When I got home I pop the hood and heard the fans working. All of them. So I don’t know what it would be. Any recommendations? Going to a mechanic tomorrow. But I want recommendations to see what it is before I hit the mechanic. Because mechanics wanna make money and they’ll tell you lies just to make money. Specially on this Covid situations. sy |
10-11-2020, 08:31 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Antifreeze/ coolant level ok?
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
10-11-2020, 08:33 PM | #3 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Sounds like the thermostat is sticking to me.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
10-11-2020, 08:54 PM | #4 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Worst case....headgasket.
10-11-2020, 08:57 PM | #5 |
It don’t come easy.
+1 on this. Would be the 1st thing to check.
10-11-2020, 10:15 PM | #6 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
air bubble in the system? have you changed your antifreeze lately and theres an air pocket in there somewhere?
10-13-2020, 09:38 AM | #7 |
Drives: 2014 Camaro 2SS Manual Join Date: Feb 2018
This sounds spot on to me. It is easy to change and a cheap way to start the troubleshooting. Worst case, it still has the issue and you have a new thermostat. Great first step before you start to look at anything expensive.
10-13-2020, 06:37 PM | #8 |
10-13-2020, 06:38 PM | #9 |
10-13-2020, 06:38 PM | #10 |
10-13-2020, 08:13 PM | #11 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
It's possible that your coolant got low enough to introduce a air bubble in the system before you had a chance to fill it up.
If so, the system 'may' work the air bubble out by itself. |
10-14-2020, 08:57 AM | #12 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Did you add to the radiator....or reservoir?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
10-14-2020, 04:42 PM | #13 |
10-14-2020, 05:26 PM | #14 | |
376 cubic inches of fun
The first step should ALWAYS be a pressure test. |
