Old 10-23-2020, 11:58 AM   #1
Camaro_Fuzion
Camaro_Fuzion's Avatar
Drives: 2022 Chevy Camaro 2SS Redline
Where can I find a crank case vent tube replacement only?
I recently swapped out with a K&N Cold air intake system. The installation still requires that part of the crank case vent tube be intact at the valve cover port. The crank case vent tube is connected to the stock Camaro 2011 cold air intake system. Where can I find this small part at or the entire tube without the entire stock cold air intake attached to it? Mine is nearly 11 years old. It's time to replace it.
Camaro_Fuzion is offline   Reply With Quote
Old 10-23-2020, 12:24 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
I replaced mine with fuel line hose.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 10-23-2020, 12:45 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
This an LS3 or L99? I think they use a different baffle assembly for the intake tubing, so that part may be different. As Ron said, you can just use the ends on yours and/or make your own, but I totally understand wanting to keep the formed hardline stock look.
Check and compare these:
https://www.rockauto.com/en/catalog/...on)+hose,11784
The one I am seeing that most looks like yours is part # 92068690, $6.59 before shipping. That's the one for the manual cars. the one for the automatics looks much longer, but it's hard to tell in the pictures.
Old 10-23-2020, 02:17 PM   #4
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
When I installed a CAI the vent tube on the rocker cover had enough straight pipe before the ridge to just slide the provided vent hose on to. I unclipped the stock plastic hose and kept it intact with the rest of the stock air box.
ADVMax is offline   Reply With Quote
Old 10-23-2020, 02:56 PM   #5
Camaro_Fuzion
Year: 2011
Make: Chevy
Model Camaro 2SS
VIN: 2G1FK1EJ9B9107187
Transmission: Automatic
Which one?
Old 10-23-2020, 04:40 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
Originally Posted by Camaro_Fuzion View Post
Year: 2011
Make: Chevy
Model Camaro 2SS
Which one?
Well crap. Those are the only 2 they show on Rock Auto.
Old 10-23-2020, 06:02 PM   #7
Camaro_Fuzion
Yes, the 92068690 is the correct part. I'm picking up one on Monday from my local GM dealership. Thanks for researching this for me. The tube contours is how I could tell it was the right part and fit.
Old 10-23-2020, 10:05 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Ok awesome. I must have read something wrong or misinterpreted their descriptions. I took mine off a long time ago since I am running a catch can and clean side separator, so I have a combination of hard and soft lines now.
Either way, glad you are getting what you need!
