11-04-2020, 07:48 PM | #1 | |
Drives: Camaro V6 2011 and 2014 V6 Join Date: May 2017
Its normal this cricket noise in Camaro 2014 V6?
Hi bros, I'm the new owner of a 2014 V6 Camaro, it's 47k miles.
The car runs well, the temperature is normal, everything is in stock, but the engine seems to me to sound like a cricket, my 2011 V6 Camaro did not make that kind of noise that I remember https://youtu.be/r67yXJ3tzx4 |
11-04-2020, 08:15 PM | #2 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
Several weeks ago there was a post regarding a chirp sound in the engine bay. Maybe you could find it and also your answer.
11-04-2020, 08:20 PM | #3 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Your hamster wheel needs lubed..
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
11-05-2020, 06:10 PM | #4 |
I know that the engine of the 2011 V6 that was LLT changed to the LFX that would be the 2014 V6, so I check if the sound my car makes is normal? Can hear more from the driver's side
11-05-2020, 06:37 PM | #5 |
Drives: Camaro Join Date: Jun 2020
Completely normal
11-05-2020, 08:01 PM | #6 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Tensioner pulley might be going bad.
11-05-2020, 08:23 PM | #7 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
The LFX injector solenoids are pretty loud.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
11-06-2020, 04:02 PM | #8 |
11-06-2020, 04:07 PM | #9 |
Banned
It doesn't sound like crickets, it has a sort of fluttering sound to it which is completely normal for the V6.
11-06-2020, 04:37 PM | #10 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I would think there are 6 crickets.
11-06-2020, 09:56 PM | #11 |
Why would it do if it wasn't supposed to? It took millions of dollars to create that sound.
11-09-2020, 06:54 PM | #12 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
My 2014 1LT Auto makes almost the identical sound, albeit not quite as loud. Here's hoping it's just the sound of a normal operating LFX.
11-18-2020, 08:59 PM | #13 |
Drives: 2015 2SS/RS Join Date: Apr 2012
There is a high pressure fuel pump located in the back of the driver side head. Makes that noise. It steps the fuel pressure up to over a thousand PSI for the direct injection. It's fine.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler 1993 C1500 Single Cab Stepside 5.3L LS Swap |
11-19-2020, 06:28 AM | #14 |
Banned
I wonder what would happen if a leak developed in the high pressure side under the manifold. Would the fuel just spray everywhere?
Just trying to imagine what 1-2K psi would do or feel like at that level. |
