09-01-2021, 11:50 PM | #1 |
Drives: Camaro 1LE Join Date: Jan 2020
Which Displacement would be better?
I have my D1x ordered and I’m going to build a new long block. Want to be at the 1000whp mark. Contemplating on either staying stock cubes or go bigger.
My question is… If ALL things are equal (CR/boost/fuel etc etc), which engine would net more power? Fully forged 376 or fully forged 408/416? Track car only. Maybe some weekend fun runs. |
09-02-2021, 02:22 AM | #2 | |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Don't be afraid of compression, and run e85 if possible. That's the only 2 other things I've got for you
09-02-2021, 06:58 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
more cubes make more power as long as you have the supporting mods to supply it. You will need to upgrade your cooling system though.
09-02-2021, 07:08 AM | #4 |
It’ll be on Flex for sure. Got the Fore ordered and ID 1700s. I was thinking around 10.5:1. Not planning on going too crazy with boost. Maybe around 15lbs.
09-02-2021, 10:08 AM | #5 | |
Cooling as far as radiator upgrade? OR better intercooler? |
09-02-2021, 10:34 AM | #6 |
Radiator at least maybe different fan setup. I'm not sure what everyone is running but have read that the bigger CI the stock system can't maintain temps. 1 7/8th headers aren't much of a restriction until I believe around 800whp. That is not to say you wouldn't still benefit from them if you are lower than that. Even I would see some gain with 2" but it breathes fine where I'm at.
09-02-2021, 01:10 PM | #7 |
For what it's worth I've always ran a half sized radiator when I was on e85 and now on m1. Cooling temps were perfectly fine.
09-02-2021, 03:50 PM | #8 | |
Do you drive the car on the street, or strictly track? Your 1/2 size is maybe more efficient… maybe? |
09-02-2021, 04:29 PM | #9 | |
Boosted Moderator
Coolant temps at the end of a one mile WOT pass are in the 190 degree range max depending on ambient temps…. Yes I drive it on the street…. Though it isn’t a blower car… While the old adage there’s no replacement for displacement, don’t forget to consider rpms…. Build a long block for higher rpms….
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
09-02-2021, 04:31 PM | #10 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I was about to say, I live in FL and never had an issue with the stock radiator on an iron 427. I upgraded to a $167 ebay radiator (physically broke the plastic one) and my temps are solid 196-201 stock fans, stock thermo, modified tune.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
09-02-2021, 06:20 PM | #11 | ||
When I meant track, I meant drag strip. No road course near me.
Any recommendations that won’t break the bank, or would the oem suffice? When I do drive on the street, it’s mostly highways. Quote:
“ Exactly what I was going to say. Adjusting the tune to make the fans run at %50 power under 192 degrees, then %70 up to 196, then %91+ made a bigger difference than upgrading my radiator.” Last edited by C@mero; 09-02-2021 at 08:21 PM. |
09-02-2021, 07:45 PM | #12 |
When I ran it on e85 I street drove the car. Iron, 3/4 filled block and a cheap dual pass, 22" wide griffin with a spal fan. Nothing exotic. Stock water pump and accessories to boot
09-03-2021, 06:32 AM | #13 |
Ok, maybe i'm wrong then. I did read a thread of an over 400 CI person having an overheating issue and everyone chimed in with what they did to combat the issue. Most was new radiator. I can probably find the thread. Now I Don't know exactly what his setup was, or if he was running E85.
09-03-2021, 08:37 AM | #14 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Anyone else think a D1X is a little small for the bigger cubed motors? Especially if you want 1000rwhp @ 15psi.
