06-14-2017, 07:16 PM | #1 |
Drives: 2014 Camaro 2LS Join Date: Nov 2015
Broke passenger mirror
Was turning into my driveway and got a little too close to the basketball hoop. Heard a loud bang and I knew I had done something to the mirror. The mirror cables are still intact and you can move it around. My dad thinks that I can take it somewhere and they can use longer screws to fix the mirror. I went to Chevy and they said they couldn't fix it because it would rust. They are quoting me around 300 for a new mirror. Any ideas on what I should do
2014 Camaro BLK 2LS, MRT 2 exhaust,CAI,Anzo projector headlights,Morimoto HID,Aftermarket fog lights,RS tail lights, Strut tower brace.
06-15-2017, 08:01 AM | #2 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
http://www.autozone.com/collision-bo...17_837008_5913
https://www.go-parts.com/gm1321415-2...nger-side.html https://www.carid.com/2014-chevy-camaro-side-mirrors/
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
06-15-2017, 10:19 PM | #3 |
Looks like these will need to be painted ?
06-16-2017, 11:21 AM | #4 |
Possibly in the pictures they look black. I was curious and chatted with a rep from the go-parts link and they said it comes in black primmer so yes you would have to have it painted. Any good body shop can do it for you a lot cheaper then what the dealership quoted you even if you have to have it painted. Paint it yourself, I painted all the items under my hood and the rims, just take your time and use thin coats. If you use a clear coat just make sure it is the same brand as the paint. When I first attempted to paint my engine cover I used dupi-color paint, let it dry over night and then sprayed it with rust-oleum clear coat and it bubbled the paint. I asked a friend of mine that works at a body shop and he said that every company that makes paint uses a different formula and only can be used with their product. Do not if that is true or not but after removing the messed up paint (PITA) and used high temp rust-oleum paint and clear coat it came out perfect. Good luck.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 Last edited by Stewart; 06-16-2017 at 11:37 AM. |
07-10-2017, 08:28 AM | #5 |
I run 2 catch cans...
Did you buy a new one, paint and install it yet? If not, you can buy a used one already painted off the classifieds on this forum. You can also upgrade to heated if you desired that feature. If only there was a guide on how to do it http://www.camaro5.com/forums/showth...95#post6577995
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
07-10-2017, 09:18 AM | #6 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
My mirror looked the same after an incident on the freeway a few weeks ago. Put some JB Weld in the bolt holes and called it a day.
