Old 03-27-2014, 11:37 AM   #1
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
Super Clean your windshield!
FaytalsCamaro is offline   Reply With Quote
Old 03-27-2014, 11:55 AM   #2
rmilcic
rmilcic's Avatar
Drives: 2013 Camaro 2SS/RS
My man, after you put on the second coat you really shouldn't wet the rags on the ground like that. You may pick up a small piece of concrete and scratch your window.
rmilcic is offline   Reply With Quote
Old 03-27-2014, 12:05 PM   #3
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Nice!
Only thing i would recomend different is instead of paper towells, use newspaper to clean the inside glass- no streaking if done correctly
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-27-2014, 12:12 PM   #4
Visago
Visago's Avatar
Drives: 2010 Camaro 2SS/RS
Sweet...good to know. I use 0000 steel wool for a lot of different things but I wasn't aware that it would not scratch glass. Definitely be checking this out.
Visago is offline   Reply With Quote
Old 03-27-2014, 12:26 PM   #5
FaytalsCamaro
I saw that too and nearly dropped to my knees in frustration yelling at this appalling act
Old 03-27-2014, 12:46 PM   #6
dwinva
dwinva's Avatar
Drives: 13 2SS/RSvert,CRT,dual-mode exhaust
I've used RainX for years. You can actually use it to remove bug residue from your windshield. I also recently learned you can use a clay bar on your windshield as well. I think this accomplishes the same thing as the steel wool. The advantage that steel wool has is it is cheaper and I imagine you can re-use it more than clay.
dwinva is offline   Reply With Quote
Old 03-27-2014, 01:10 PM   #7
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Originally Posted by Comrando View Post
I haven't tried it on a windshield but a damp dryer sheet (new or used) wipes bugs off the bumper.
it works on windshields too
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 03-27-2014, 02:15 PM   #8
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
In my opinion I would never use anything on a surface that is softer than the item you are using without lubricant. That's why I use a razor blade with a very liberal amount of glass cleaner, and then follow it up with clay barring. Best technique I've ever used on mine or any of my clients cars. Here is a video of Larry at AMMO NYC doing it so you know I'm not just crazy.
http://youtu.be/q4WwOrkgXlc
13lstuner is offline   Reply With Quote
Old 03-29-2014, 09:03 AM   #9
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
I've seen these recommendations over the years and personally find it easier to just clay my windows. Then Wash with your favorite glass cleaner and MF towel, then seal. I use Adams product line for cleaner and sealant but there are others.
WiSSDiver is offline   Reply With Quote
Old 03-29-2014, 09:55 AM   #10
1LE Captain
1LE Captain's Avatar
Drives: 2014 Red Rock 2SS 1LE RS NPP
Definitely use Iron Cut after you steel wool the windshield. The tiny little steel wool pieces you can't see are all of the bottom of your windshield now. If you don't remove them they will rust.
Adams glass cleaner and sealant work very well for me.
1LE Captain is offline   Reply With Quote
Old 04-03-2014, 11:20 AM   #11
Jeffm
ICANHAZ
Jeffm's Avatar
Drives: 2013 CRT 1SS/RS
I would just clay it
Jeffm is offline   Reply With Quote
