12-03-2016, 11:24 PM | #1 |
A/C Issue
I have owned this car for 10 weeks I bought it second hand and right hand converted to suit Australia conditions
The problem is that whilst driving the A,c will cut and drop away and begin to blow fan air only and will cut back in and begin to blow cold air again for no reason it seems to work better at at high revs from a standing start I have the gas checked and reading are within 10% of full The repairer told me to turn the circulation button on as to cool the same air but that was worse off today The main thing I notice is the majority of the air come from the middle vents and both side vents are piss poor in comparison unfortunately There is a massive shortage of these cars in Australia to compare with\\\By the way it's summer here and is 30 to 38 c There you go on the right hand conversion Thanks and Merry Christmas from Aus |
12-03-2016, 11:35 PM | #2 |
Pay attention to details
Drives: 2012 ZL1 Join Date: Aug 2016
Mine did the same thing. I found the system overcharged. The pressure would get high enough to trip the high pressure switch and temporarily disengage the compressor. Good luck.
12-04-2016, 09:34 AM | #3 |
How many miles do you have? I believe your warranty is three years or 36k miles. I would go to the dealership. I removed my AC components for weight reduction and because it's not my daily car.
Car mods: never enough!
12-04-2016, 09:08 PM | #4 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
I had a very similar issue, turned out to be a clogged condenser and a bad compressor. All was repaired under warranty!
12-12-2016, 04:30 PM | #5 |
Buckeye
Drives: 2013 2SS RS 1LE Join Date: Apr 2012
AC Issue
I had the same issue the first summer I had my 1LE.
Too much R134 (I think that's what it uses) was installed at the factory. The dealer drained out ~ 1 ounce and it has worked wonderfully the last 3 summers.
12-13-2016, 03:12 AM | #6 |
OK turns out the problem has been fixed unfortunately Australia doesn't have Chevrolet dealers and the junior company Holden won't cover a Chev warranty
It turns out that the company that did the right hand conversion of the dash had left the main earth loose and that caused the the compressor to cut in and out in short intervals I have now driven it on 5 occasions and a happy boy in a Aussie Summer of 40 deg Have a great Christmas and thanks |
12-14-2016, 06:08 PM | #7 |
Nice. You mean, ground, right? Anyways, glad you're ride is fixed.
12-14-2016, 06:47 PM | #8 | |
12-15-2016, 04:53 AM | #9 | |
Now as for the conversion to start a car like ours in Australia are worth between $75,000 to $90.000 so they are rare about as rare as a unicorn the conversion costs are also high about $38,000 because of the Airbags conversion and an number of added indicators to front guards or fender as you boys would call them .Also the front steering rack and pinion has to be reconfigured out of a GM Holden sister company and the firewall re worked to suit. The only remainder is the boot release or Trunk release is still in the left door trim Also our rear indicators have to be orange and not red so they modified the reverse light as a indicator and added the orange insert tires or tyres in Aus are also expensive for these babies Michelin are approx $460 each and we can't get the BFG comp 2 in AUS but we can get KUMOS which are about $375 each Yet I would never get rid of it most teenagers love her as much as me and she turns heads men and women love the Camaro alot more than the Ford Mustangs which are now being brought into Australia as right hand drives from the US Michelin Michelin |
12-15-2016, 05:02 AM | #10 | |
If you look at the pedals the accelerator is on the right side brake in the middle clutch on the left we change gears wit our left hands I had the pleasure of of driving in Hawaii last year the hardest thing was keeping right turning opposite to the last 30 yrs of driving but judging car parking spaces was real hard having the majority of the car on the wrong side of you driving but you get the hang of it or hit head on with a car |
