Old 06-25-2020, 09:33 PM   #1
mred2nice
mred2nice's Avatar
Drives: 2013 Camaro ZL1 & 1979 10.5 Camaro
Rear Suspension Help Cleveland Ohio
Hello There Everyone
I need a little help/advice. I have a 13 and am experiencing, what seems to me, odd rear suspension behavior. The rear seems very very stiff. Also, when going over multiple imperfections in the road in a row, the rear feels like it is skipping/floating to the right. I must be sure to have 2 hands on the wheel.
I have it set on Tour mode.
I have been going to the local car shows looking for another ZL1 in hopes of chatting with the owner. Unfortunately, I have been unable to find one.
Any insight/suggestions are appreciated.
Thanks,
Ed
mred2nice is offline   Reply With Quote
Old 06-25-2020, 09:35 PM   #2
quinthawk
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1
Your rear shocks are probably leaking and need to be replaced.
quinthawk is offline   Reply With Quote
Old 06-25-2020, 10:52 PM   #3
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
If your rear shocks are leaking they aren’t going to be stiff, they are going to be soft and bouncy.
ZMEnow is offline   Reply With Quote
Old 06-26-2020, 12:08 AM   #4
'10CamaroDude
Drives: 2010 Camaro LS
Any time the car bounce-slides when turning is a sure sign of bad shocks/struts.
However, the rear multi-link suspension requires alignment. If it's off, the car can
slide on bumps, or if bushings are bad.
'10CamaroDude is offline   Reply With Quote
Old 06-26-2020, 09:52 AM   #5
quinthawk
See post #10 in this thread.
https://www.camaro5.com/forums/showthread.php?t=381443
Old 06-26-2020, 11:06 AM   #6
ZMEnow
Dont care what he said, I have gone through 3 sets. When they leak they get soft. The metal particles in the fluid overtime lose their properties to take a charge, also as you loose fluid you reduce the ability to compress. Both result in a softer shock. The only case where the struct would get harder is if it were bent. And its location on the Z makes that almost impossible with out bending the trailing arm.
I am not saying he doesn't have a strut issue, but the description he gave would not match that of a failed strut, but more of a collapsed bushing in either the lower arm or something else.
Old 06-26-2020, 08:35 PM   #7
mred2nice
mred2nice's Avatar
Thanks for the replies. Upon inspection, there is a fine oil mist on the right rear suspension. Also, when I bought the car I found out it was wrecked in the right rear and the suspension is not original on that side.
What kind of alignment do I need? Is there something special for the rear or is it just a normal front/rear alignment?
Thanks,
Ed
Old 06-26-2020, 10:29 PM   #8
ZMEnow
Thanks,
Ed
Do you have a coupe? FE5 see attached.
