JUICEDMOTORSPORTS
Old 04-08-2015, 10:23 AM   #1
springer03
Drives: 2013 Camaro 1lt BRM
Part number?
Can anyone tell me the part number for the hose that you cut to install a catch can is?
I tried looking it up but I have no idea what it's even called.
Thanks.
Elite Catch Can(Sold), CAI Intake(Sold), Vmax Ported Throttle Body,4Pack Gauges(Sold) Solo LFX Cat-back, Solo Hfc's
springer03 is offline   Reply With Quote
Old 04-08-2015, 10:59 AM   #2
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
You just need some 3/8" hose from Autozone. That's all that these kits use.
Edit: misread that. I'll have part number in a moment
All I can find is the part number for the clean side. What did you do?
6bangerBOOM is offline   Reply With Quote
Old 04-08-2015, 11:45 AM   #3
8863
Drives: 2013 Camaro 2LT RS
I would like the part number too. Just in case a dealer gives me crap about my catch can, I can remove it and put the stock hose back in if I need service.
8863 is offline   Reply With Quote
Old 04-08-2015, 11:52 AM   #4
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
12638437
Jason@JacFab is offline   Reply With Quote
Old 04-08-2015, 12:37 PM   #5
springer03
I'll be trading in my car soon so I wanted to put everything back to stock.
thanks Jason! That's cheaper than I thought.
Will be trading up to an 8 i a couple of months!
Old 04-08-2015, 12:41 PM   #6
springer03
Is that right $7.57 at Gmpartsdirect?
Is that the hose with the connecters?
Old 06-12-2017, 12:10 PM   #7
p.s.
Drives: 2014 v6 manual
bumping an old thread because I'm wondering if the o-ring that supposedly goes with the tube is necessary to replace? This o ring:12616909
Everyone wants 12 bucks to ship the thing and I'm not going to bother if the old one is fine which it should be after only a few years.
p.s. is offline   Reply With Quote
Old 06-12-2017, 12:40 PM   #8
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Shouldn't need to be replaced unless damaged. I've taken mine off a few times and is fine.
Lil' Nasty is offline   Reply With Quote
Old 06-12-2017, 03:12 PM   #9
p.s.
Great, and thanks for the quick reply.
Old 06-12-2017, 03:39 PM   #10
ARCTIC
ARCTIC's Avatar
Drives: 2017 1SS convertible
I have a more basic (dumb) question: What is the catch can supposed to do? How tough is it to install?
Red 2017 Camaro 1SS Convertible
ARCTIC is offline   Reply With Quote
Old 06-12-2017, 04:43 PM   #11
Dragonman
Dragonman's Avatar
Drives: 2015 1LT OBE
It captures oil in the PCV system and prevents it from getting into the intake manifold, which in turn keeps it from coking up the valves. I've yet to install one in mine but from everything I've read about it they aren't hard to install.
_______-2015 1LT JUSTICE----------------------------------1997 B12-___________
Dragonman is offline   Reply With Quote
Old 06-13-2017, 09:58 AM   #12
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Simple to install and a good idea on DI engines. It really is amazing how much mine catches between oil changes. To think of all of that being burned through the top part of the motor gives me shivers.
Very happy I decided to install mine with under 3k on the car.
If Im not mistaking... the Gen6 comes with one stock now. Hm. Wonder why...
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 06-13-2017, 10:31 AM   #13
ARCTIC
ARCTIC's Avatar
Huh... That is interesting. Anyone verify this?
My car has 46,000 on it now. The damage is probably already done.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
