Old 10-31-2017, 07:34 PM   #1
p.s.
Drives: 2014 v6 manual
bled out radio head unit lcd horizontal lines
I had my radio (head unit) replaced under warranty because it was holding moisture and it the display looked like crap, like so:
So I got a new one and at first it looked great and then I starting noticing the same bled out look but not nearly as bad. I'm going to assume there is something else going on with my car unless these all look like crap maybe? I appreciate any input as i'm trying to decide if this is normal. I can't be the only one with this defect.
p.s. is offline   Reply With Quote
Old 11-01-2017, 03:45 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Is it cold outside?
Orange Krush II
Old 11-01-2017, 03:58 PM   #3
p.s.
Originally Posted by olblue75 View Post
Is it cold outside?
yes it seems to be worse on cold mornings.
Old 11-01-2017, 04:05 PM   #4
p.s.
To be clear its still noticeable when warm just seemed a bit worse when its cold. Oddly enough when it was first replaced it looked great for a bout 5 minutes. I read something about interference of led's, possibly something in the car is interfering.
I couldn't find anyone else with this same issue, so if you have had this issue this is the spot to post.
Old 11-02-2017, 07:09 PM   #5
p.s.
Could I get this moved to the problems thread? Might get more response there.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
