Old 01-11-2021, 05:28 PM   #1
TuneAFish
TuneAFish's Avatar
Drives: 2015 Camaro SS M6
How much boost before changing ring gap?
I'm just doing some exploration, but I was thinking about twin turbos, and I'm wondering how much boost can you add to a stock bottom end car (intake has never even been off) before you have to take it apart and adjust ring gap?
I tried to look through the existing threads but couldn't find this being discussed.
Thanks
-Rad Air CAI
-Z28 Strut Brace
-GPI SS3 Cam & BTR Springs
-2" Texas Speed Headers
-AEM Wideband AFR
-3" Full Exhaust w/Hi-Flow Cats & Single Chamber Flowmasters
-McLeod RXT twin-disc w/Aluminum Flywheel
-Yukon 4.11
-Nitto 555 G2
TuneAFish is offline   Reply With Quote
Old 01-11-2021, 06:46 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX427 TT
You're going to be limited by cylinder pressure and the strength of the thin ring lands on a stock LS3/L99 (which ain't that robust), and the aluminum block. If you're going to be taking apart the motor, might as well beef up the pistons/rods with forged components and you'll be able to make a few more hundred HP. That being said, numbers I have seen and experienced range from 700-850rwhp on the SBE motor, and 850-1000rwhp with forged components. Your longevity will depend on your tune and the continuous amount of power you're pushing.
In excess of 1,000WHP
LSX427 | AGP 65/65 TT | BTR Equalzer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | NGK BR7EF | RPM Lv 7 TR6060 | AGP's Fore Triple Fuel | Monster LT1-S Triple | 3.25 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 01-12-2021, 03:37 PM   #3
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
For what its worth: I asked the guys at GPI the same question and they told me they see guys all the time running just fine with 12psi but that was the limit. (Thats what I am doing)
2012 2SS/RS, L99, no cats/mufflers, Holley Sniper low pro intake, Holley Sniper fuel rails, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. Snow methanol setup. custom 3gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, vitesse throttle controller, Innovate SCG-1, Hurst shifter with tap shift mod
Tarendor is offline   Reply With Quote
Old 01-19-2021, 09:50 AM   #4
TuneAFish
TuneAFish's Avatar
Thanks for the replies.
Tarendor - I was reading through some of your build threads and I was wondering, did you ever get that thing to the dyno? I'm also curious, are you still using that ZL1 pump? I was wondering if you'd run out of fuel with it at 12psi in the upper RPM range.
-Rad Air CAI
-Z28 Strut Brace
-AEM Wideband AFR
-Yukon 4.11
-Nitto 555 G2
Old 01-21-2021, 02:18 PM   #5
Tarendor
Tarendor's Avatar
I have not gotten to the dyno, I am down for winter.
When I talked to the guys at GPI when I was looking to buy my injectors they were confident that with the ZL1 pump (fpcm programmed by me using HPT) AND the ID1050x plus methonal that I would be good to 12psi with no issues. (SAID the methonal was optional too)
I have not even turned on the methonal yet.
However I am adding a msd bap. that I got in a trade because....why not? lol.
I have not ran out of fuel at all, but in tuning I only got up to 8psi before crappy weather hit and I parked him.
Old 01-22-2021, 02:18 AM   #6
TuneAFish
TuneAFish's Avatar
Originally Posted by Tarendor View Post
...because....why not? lol.
Seems logical :-)
It will be summer before I'm ready to add boost, so please keep me posted. I'm curious to hear how things go as you turn the PSI up!
-Rad Air CAI
-Z28 Strut Brace
-AEM Wideband AFR
-Yukon 4.11
-Nitto 555 G2
Old 01-22-2021, 11:31 AM   #7
Tarendor
Tarendor's Avatar
At 8psi its very sketchy hahaha I can't wait to see the final result myself. (I have full suspension and good tires but its sketchy still and I am not going to put slicks on him)
Old 01-22-2021, 01:38 PM   #8
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
I am around 13psi on the SBE but running E85 and two pumps on 105lb injectors.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 01-22-2021, 01:39 PM   #9
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
I'm sure you have done your research on the forum but just for nothing...back in September I installed a BTR stage 2TT camshaft along with the AGP twin kit. Turbos are 57/57's, Injectors are AUS 1000's and I have a JMS voltage booster for fueling,all else is stock. On a loaded hub dyno I made 650 RWHP and 619 RWTQ on 8lbs of boost. I did not have my 1LE dynoed before the install but assuming the low end of what I have seen on this forum (370 RWHP), I am making 35hp per pound of boost. Just take this for what it's worth we all know dynos are just a tool. I'm sure you are already amazed at the power, it's stupid fun!!
HOJO is offline   Reply With Quote
Old 01-22-2021, 02:25 PM   #10
Tarendor
Tarendor's Avatar
As funny as it may seem...I don't care about the hp numbers.
What I want is 12psi of boost at a solid lambda and decent timing. Then I am going to add the methonal and add more timing...its all relative...compared to when I got the car its crazy lol. Their will always be faster cars out there but I plan on hurting some feelings this summer for sure.
Old 01-23-2021, 10:23 PM   #11
TuneAFish
TuneAFish's Avatar
Thanks for the insights!
-Rad Air CAI
-Z28 Strut Brace
-AEM Wideband AFR
-Yukon 4.11
-Nitto 555 G2
Old 01-27-2021, 10:07 AM   #12
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks
Ring gaps can not be tied to a boost number as there are too many variables that effect actual combustion temperatures which is what really determines ring gap requirements.
You could butt the rings by overheating the engine all stock.
You can make 800 Wheel and never butt the rings.
It is all about temps and ring growth.
Ted.
www.jannettyracing.com
Celebrating 34 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 01-27-2021, 11:08 AM   #13
Tarendor
Tarendor's Avatar
Ted,
Do you reccomend converting to the 4 corner steam port vs staying with the factory 2 corner to help prevent hot spots?
Old 01-28-2021, 08:18 AM   #14
JANNETTYRACING
Ted,
All of our high powered engines have 4 corner, but not always possible with all combinations.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
