01-16-2020, 08:38 AM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
question on LS7 intake
So I got the LS7 intake with my GPI max kit. My factory map sensor out of my 15 Camaro SS is retained by a screw. The LS7 intake doesnt have a spot for a screw. Looks like it just clips in. Anyone happen to know a part# for what sensor I'm to use? No boost currently. Thanks
01-17-2020, 02:58 PM | #2 |
Anyone? This bridge would have had to been crossed for anyone doing the gpi max kit themselves with the ls7 intake
01-17-2020, 03:54 PM | #3 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
Did you contact GPI directly and ask them what they use?
Rhino79 on here is Ryan at GPI, he's good at responding to PMs
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers |
01-17-2020, 06:57 PM | #4 |
I just sent them a message
01-18-2020, 07:21 AM | #5 |
So they said a 1 bar ls7 map sensor is what im after. Im having trouble here, but it seems the 14 camaro z28 had the ls7 motor. The acdelco part# 12644569 seems to fit but not 100% sure. Amazing how this isnt easier to find lol. Now not sure if that will work and also if the plug is the same
01-19-2020, 11:36 AM | #6 |
Well anyone else doing the gpi max kit themselves and option for the LS7 intake, that seems to be the correct sensor part# in my above post. Its ordered and ill report back to 100% confirm
01-21-2020, 12:05 AM | #7 |
01-21-2020, 12:06 AM | #8 |
That should be the sensor needed for those who are looking
01-21-2020, 12:20 AM | #9 |
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man Join Date: Aug 2015
Plug is different and I believe calibration is different in the Ecu.
01-21-2020, 06:27 AM | #10 |
Yes, calibration will be different. Not sure on the plug yet. Sensor should be here tomorrow and I'll let you guys know. Thanks
01-22-2020, 05:42 PM | #11 |
Ok, so the sensor is correct and fits in the intake perfect. The plug is wrong. Still a 3 wire, but gonna have to change out the factory plug it seems. Guess I just need a factory LS7 map sensor harness?
01-22-2020, 06:31 PM | #12 |
Wonder if anyone makes an adapter. I thought the LS3/LSA/LS7 harness was the same, just the sensor was different.
Edit: Doing some research it looks like the difference is between Bosch and Delphi sensors/connector styles. Apparently the early LS7s used a Delphi connector style and didn't move over to the Bosche style until later. Wow. What a pain in the ass. There has got to be a way to do this without having to rewire the harness. Did the LS7 use the Gen III LS style connector? If so, they make a harness for that.
01-22-2020, 06:54 PM | #13 | |
01-22-2020, 06:57 PM | #14 | |
Good luck man.
