01-21-2020, 12:52 PM | #1 |
Drives: 2015 2SS RS Join Date: Jan 2020
speed engineering long tubes and which high flow cat?
1. who here has s.e. long tubes bolted on and are you using no cat pipes? how does it sound?
2. who here is using s.e. long tubes with high flow cats and which high flow cat are you using? hows the sound.... 3. whats your catback or axle back ? im gonna purchase speed engineering long tubes and dunno which to go, no cats or high flow cats? i dont want extremely loud especially want more quiet while cruising....
Darkness
01-21-2020, 01:10 PM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Tsp sells a set that are plug n play, you can get some universals from Magnaflow, flowmaster, eastern catalytic, or find a local shop that does high performance exhaust as they’ll likely have some on hand. Universals will need to be welded in
1. Lots of rasp and loud. I’ve done this and while it sounds good, I got tired of the smell and rasp 2. I’ve got 100 cell cats and it’s perfect. Less rasp and smell, but still loud 3. 3” catback with magnaflow mufflers. Sounds great, some drone on hills If you want quiet while cruising look at Solo w/ j pipes, oem mufflers, oem NPP mufflers, Corsa, Borla atak, some magnaflows and I’m sure I’ve missed a few others. But those will be the most drone free exhausts
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 01-21-2020 at 01:21 PM. |
01-21-2020, 01:14 PM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
https://www.camaro5.com/forums/showthread.php?t=566388
No cats 2.5 borla atak. No drone, drives like a gentlemen while your foot is out of it. Loud as **** at WOT especially under boost.
01-21-2020, 01:24 PM | #4 |
Drives: 15 Camaro SS Join Date: Oct 2018
SE longtubes with no cats. Corsa extreme, sounds amazing but there is a little rasp at a certain rpm. Quickly goes away and it screams like no other at WOT. Currently installing the gpi max kit so curious how loud its gonna be when I'm done. May have to throw some hfc on it
01-21-2020, 02:18 PM | #5 | |
Dynomax bullets fit after the x pipe like a glove. Corsa also has some round mufflers that will fit in the same place
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
01-21-2020, 04:55 PM | #6 |
Great info....i appreciate the good stuff u guys post...ill be ordering s.e. lts...just deciding whether to use no cat pipes or hf cats...i have a jba catback so...once connected i may or may not switch the catback exhaust depending on sound....
So u guys are basically saying s.e. long tubes and catless pipes will sound really loud cruising? Loud dont bother me at all when accelerating etc , i want just much lower sound when on cruise control....other than that im showing out lol Any videos of s.e. long tubes and no cats vs w/hf cats?
Darkness
01-21-2020, 05:15 PM | #7 |
Mine is not loud when cruising, only under acceleration. You might want the cats if you don't want exhaust smell. I didn't want to do cats because i didn't want to worry about melting them down but i do get more exhaust smell.
01-21-2020, 05:33 PM | #8 |
Has that much smell with no cats?
Darkness
01-21-2020, 05:35 PM | #9 |
on catback exhaust systems the obvious size is 2.5 inch right? 3 inch catbacks are too big or not? Any problems using 3 inch catback? Any difference?
Darkness
01-21-2020, 05:51 PM | #10 |
The smell isn't bad but i can smell like car sometimes. 3" isn't really need unless you are heavily modded. If i end up going towards the 800whp level i would probably change over to 3" and might go with 2" longtubes.
01-21-2020, 07:13 PM | #11 |
It can get very stinky (depending on your tune), mine is. Especially in drive throughs. A Burger King cashier once told me 'Man I love that smell. It smells like power'
It really comes down to whether or not you (or your significant other) likes that smell. Personally, I love it. But it will also linger on your clothes, especially if it gets cold out. I could not give two Shi*s if strangers don't like it though.
01-22-2020, 11:10 AM | #12 |
Thanks for the heads up. May have to do that when I'm done. Guessing the increase in compression and massive am isnt gonna quiet it down lol
01-22-2020, 12:27 PM | #13 |
Drives: 2015 blk 1 SS Join Date: May 2012
Was behind a Camaro w/o cats on the way to a show,smell was obnoxious, burning my eyes.
15 1 SS
01-22-2020, 12:31 PM | #14 |
no sure what ill do
i do know it will be long tubes connected to ???? connected to jba catback exhaust, cai on front side with a tune from dyno steve...this is the only mods ill do except ill prolly get my tb ported to a 95mm perhaps......i may go with hf cats to keep from stinking up the joint lol.... what is a safe but better than stock tb size to port or buy outright?
Darkness
