01-22-2020, 05:48 PM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Oil pump pics disassembled
So I have mine all torn down and am in the middle of changing the timing chain to a C5R. Figured I would snap a few pics for those who need some help on an oil pump change out. I found that I could access the bolt in the pickup tube by dropping the oil pan down roughly 3/4". Stuff rags in the pan in case the bolt slips out of your fingers. Also, installing the oil pump is much simpler if you take it apart. Have some pics of whats inside. not much to it
above is the pic from the front showing the pick up and o-ring below is the oil pump with cover off and with the 2 gears out |
01-22-2020, 05:49 PM | #2 |
Much easier to reassemble with the guts out
01-22-2020, 07:38 PM | #3 |
Drives: 13' 1LE Join Date: Apr 2012
Yes its a good way to be sure not to pinch the oil pump oring.
Or you remove the whole pan if you did the 'cutoff crossmember' mod https://www.camaro5.com/forums/showthread.php?t=563186 Some shim the oil pump, well melling do advice to do it. The hardest part is to find the little plastic shims to do it...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
01-23-2020, 02:15 AM | #4 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Thank you for information.
And.... What is this....? |
01-23-2020, 03:24 AM | #5 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Electric power steering rack an pinion.
Orange Krush II
01-23-2020, 06:37 AM | #6 |
Yup. Its on my 15. I think they started that in either 13 or 14
01-23-2020, 07:34 AM | #7 |
01-23-2020, 08:44 AM | #8 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
That is the way I did mine - much easier....
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
