07-05-2020, 12:24 PM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
2017 ZL1 A10 transmission fluid/filter change part deux and short bio
This is the second transmission fluid change and my car currently has 9000 miles. The first change was at 6000 miles (probably too long considering its use). Here is a link to part 1 so I don't repeat myself:
https://www.camaro6.com/forums/showthread.php?t=553829 OK...because everyone is so sensitive these days, a brief bio is necessary so everyone can relax and hopefully understand my intentions. I feel Camaro 5/6 is an amazing group and resource. Personally, I have gained much knowledge and many friends because of it. My experience dates to my first vehicle purchased which was a 1968 El Camino in 1985. The first trip of mine down the dragstrip(17.0@85ish) was that same year, and I have been hooked as a shadetree mechanic ever since. Two of my very good friends are ASE certified mechanics and one of them is a shop owner. I have helped restore a 1966 Chevy II, 1966 Corvette convertible, and a 1972 Corvette coupe all before car restoration was more mainstream (late 1980's). As for transmissions...I have serviced or installed "shift kits" in many GM transmissions including Powerglide (aluminum & cast iron case), TH350, TH400, 700R4, 2004R, 4L60E, 4L80E, 6L80E, 6L90E, and our 10L90. Strangely, my career path led me to dentistry, and I have been a general dentist for 25 years. I am 51 years old & married with two children ages 13 & 15. Road course HPDE driving/instructing has been my latest interest (~10yrs) which is IMHO the most appropriate use for a ZL1. These cars are amazing! OK...since that is off my chest we can get down to business: check the link above for previous pics. Here is a pic of the transmission pan in which the fluid appears much more red compared to the orange from the last change. I used 7 quarts as the magic number again. Have a great day everyone!
07-05-2020, 12:26 PM | #2 |
one more pic:
07-05-2020, 02:13 PM | #3 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
My first vehicle was a '65 El Camino, I think I replaced basically everything on the car in the 5-6 years I owned it, so I learned to work on cars the hard way (including replacing the trans from under the car - on jackstands - by myself). No traction either, just about killed myself on icy roads in UP of Michigan. Car was a death trap. "Character building" my dad would say
Trans fluid change - this brings up the age old debate of flush vs drain. Flush is always superior if the transmission and fluid is in reasonably good condition, but I don't know if GM dealers are even set-up to do it. As far as I know a simple drain will still leave multiple quarts of contaminated oil in the torque converter. If you're draining regularly I would install a drain plug kit ASAP. |
07-05-2020, 03:33 PM | #4 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Funny Stephen, my first car was a '72 El Camino. It got me hooked on wrenching, did stupid stuff with it as I was learning. Rebuilt the motor, swapped differentials and converted to TH400. Finally wrecked it, doing something that was not the smartest thing to do. Oh well, it was good being lucky and no one got hurt.
I'll be doing the drain, filter and fill also.
07-05-2020, 04:11 PM | #5 | |
07-05-2020, 04:27 PM | #6 | |||
12-21-2021, 07:40 PM | #7 |
Pistons Lover
Drives: cars! Join Date: Apr 2010
Thank you for sharing your experience.
The only DIY A10 "oil change" I found on the web. I am having a fault code P0700/P0708 and need to drop the tranny oil pan to replace my AT Gear Position Sensor 24289773 :(
2017 CAMARO ZL1 10AT |
12-21-2021, 08:54 PM | #8 |
Should be a pretty simple job, just nasty. These trans are pain in the ass since they have no drain plug, and you will also have to drop the valve body to have room to work on the positioning sensor. If your someone that changes your fluid often like me. While your pan is dropped add a drain plug. Makes life so much easier down the road.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
12-21-2021, 08:55 PM | #9 |
Welded in at the back of the pan.
12-22-2021, 01:43 AM | #10 | |
Pistons Lover
Hope it is not a sensitive part, especially I don't have workshop manual . Sadly I'm not from the USA... very hard to find locally parts... even a drain plug I'm draining just for that sensor, car only has 4000 miles since 2017.
12-22-2021, 03:25 AM | #11 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Nice write up again Stephen.
I’m impressed with the amount of different GM transmissions you have worked on. The topic of flushing then having a problem afterwards has happened to myself as a tech twice. Once on a lower km vehicle and once on a mid life vehicle which to me would be like 200000kms. It’s rare but it does happen. The higher mileage vehicle was a regular customer and flushed his vehicles every 50000kms. Regardless, the pics you have taken look clean to me. Looks like there is pretty much nothing on the magnets or in the bottom of the pan which obviously is a good thing as you know. Regarding ElCaminos. My older cousin and I went out one night to play pool. We brought home an older broad. I had to go home that night. My cousin threw me the keys to take home his 1985 ElCamino. It was a 4 speed. First time I had driven a manual. I was 15 years old. Didn’t even have a license. Surprisingly I didn’t even stall the car. Great times. Hopefully one day I can own one. |
12-22-2021, 09:55 PM | #12 | |
It’s not a bad job pulling the valve body. You will see it comes out as one big piece. You will need it out to work I would assume. Not much space working around it. If this doesn’t work and you a valve body issue just message me.
12-23-2021, 03:31 AM | #13 | |
Pistons Lover
I have seen some DSG valve body, but never really touch one. Probably scared because it is 10 speeds I am trying to find a 2017 ZL1 workshop manual online to buy in PDF format Amazed it is not available... will need the torque specs ect.... and what not to do. Thanks
12-23-2021, 06:45 AM | #14 | |
https://www.alldata.com/diy-us/en/fi...plan?vid=56907
