02-27-2021, 07:32 PM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
SPL Rear Toe Arms with eccentric lockout review
These toe arms are amazing quality and fit the "simple yet elegant" classification. The factory toe arm uses a POS eccentric and the single use bolts which cause grief, worry, & potential loss of alignment settings. I know these units have been the talk of the forum previously. With my new ZLE, I decided to opt for these units to help with all of mentioned issues.
The install was amazingly easy and everything was excellent fitment. Make sure to measure the factory toe arm hole center to hole center and have a 3/16" allen wrench handy to lock the ends. Older spherical ended arms like this used jam nuts which were a PITA so this new style "sleeve lock" is really nice. Also, measure the toe with a tape measure from bolt center to bolt center before removing the stock part. This will get you in the ballpark prior to a necessary new alignment. A few pics:
02-27-2021, 07:46 PM | #2 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I just did all rear SPL components and I can tell you it is top quality. And I will be doing the front end in the near future.
02-27-2021, 08:43 PM | #3 |
Drives: HBM ZLE Join Date: Aug 2017
How do you like the rear upper and lower traction arms? Notice a difference? Really like the toe rods, front end stuff feels great so far as well. End links might be in the future! These SPL products are nice
02-27-2021, 09:01 PM | #4 |
I have not drove the car snice installation as I'm doing all my winter projects and also the weather here in NJ isn't nice.
02-28-2021, 08:30 AM | #5 |
Right on, I'll be keeping an eye out for your impressions once the weather gets better
02-28-2021, 10:35 AM | #6 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
Ok on race car that stays dry, but exposed metal "balls" on rod eye will mean very short life.
They do sell boots you can slip over and treat them with Fluid film or similar corrosion preventative that stays put.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
03-01-2021, 11:56 AM | #7 |
Drives: 2016 1ss camaro Join Date: Feb 2016
i have em on my track focused ss car works great no toe changes quality usa made parts!
03-01-2021, 02:28 PM | #8 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
It seems like most people have no issues with their stock toe links. I speak for people that actively track as well.
Got to wonder if it is worth $500 for someone who only tracks once or twice a year.
#SAVETHEMANUALS
03-01-2021, 02:34 PM | #9 | |
probably not but for somebody that tracks their car 6-12 times a year its definately
03-01-2021, 09:21 PM | #10 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Just had these installed on my ZLE today. Drove home 80 miles. Car feels solid. It seemed to walk less on power but not entirely sure. Can't say I noticed a massive difference yet. Will find out on track.
Not planning to replace all the arms without evidence of meaningful improvement. I did the toe arms to get rid of the eccentric and its associated slippage.
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
03-01-2021, 10:07 PM | #11 | |
03-01-2021, 10:17 PM | #12 |
All I can say it's they are made to last. They only thing I will be ordering extra is the blue locking screws just incase while alignment they strip. As far as functionality I haven't driven the car so no feedback there, but I can definitely see if being easier for alignment and also easier for tech to hit desired spec.
03-02-2021, 03:17 AM | #13 | |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
They look nice Stephen..... A nice side effect.... |
04-14-2021, 12:01 PM | #14 |
Drives: 2018 2SS 1LE Join Date: Feb 2018
Anyone been tracking hard with these and measured rear toe changes? Can always feel my toe out after a session or two at buttonwillow and leaning towards these
2018 1LE
2nd 6th gen SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid |
