#Camaro6
Old 04-05-2021, 01:40 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
2021 ZLE camera mirror adjustment help
Thanks for any help but I cannot see an obvious way to remove the black plastic around the rear view mirror to tighten the pivot. Stupid mirror is adjusting down on every rough patch on the track. Anyone have any experience removing or adjusting these camera mirrors? Tried a search but didn't really see anything. Thanks!
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-06-2021, 05:52 AM   #2
Stephen12ZL1
Drives: '21 ZLE A10
anyone know??
Old 08-22-2021, 05:49 PM   #3
jones1090
jones1090's Avatar
Drives: 2020 Rally Green Metallic 1SS 1LE
Having the same issue in a 2020 SS with camera rearview mirror. Was able to simply pry the plastic cover off with a small flat blade screwdriver, but cannot really see how to tighten the pivot down to keep it from falling down every time the car goes over gators. Anyone have some insight?
jones1090 is offline   Reply With Quote
Old 08-22-2021, 06:03 PM   #4
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
I don't have this issue, but seeing that both of your cars likely are under warranty, I'd make this the dealership's problem. That certainly should not be happening and they'll fix it under warranty.
Bonus points if you can share how they fix it with the community so when someone out of warranty runs into this issue, the information is readily available.
2019 ZL1 1LE | M6 | SGM | PDR | CF Dash | Nav | Wheel Locks
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses
Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6
YouTube
RamAir02 is offline   Reply With Quote
Old 08-22-2021, 08:50 PM   #5
Stephen12ZL1
Drives: '21 ZLE A10
so, as a follow up to this issue...I had GM quality control involved and they had a replacement mirror sent to my local dealer with an updated mirror. The bill from the dealer to GM was something like $1100! It fixed the issue for the most part. It adjusted down once at Watkins Glen on a really rough gator in the bus stop. Otherwise, at VIR it has been solid since the replacement.
