12-02-2015, 08:23 PM | #1 |
Sarcasm loading --------
noise from rear end - one wheel spinning
Do I need to change the rear diff oil?
Service manual states changing at 15k for ZL1. I'm hearing noises (sounds like clutch disks in diff) when turning after the car sits for a while (like overnight), and lately have had issues with one wheel spinning. It wasn't an issue when I got the car early in the year, I put about 5k miles on it this year only.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
12-02-2015, 08:51 PM | #2 |
Drives: 2013 ZL1 Join Date: Mar 2013
My 13 model had the same thing happen to it and GM ended up changing the complete rear axle out for me. The tech tried and tried to get the noise to stop but could not. So good luck and do not let them just try and slip it by you and say it is normal.
12-02-2015, 09:05 PM | #3 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Put car in neutral. Lift 1 rear tire off the ground with a jack. Leave the other on the ground. It should then take about 100 lb-ft of torque to turn the lifted wheel.
If it turns too easily the clutches are worn out. You shouldn't be spinning just one tire.
Bryan 2018 ZL1 M6
12-02-2015, 09:46 PM | #4 |
The noise goes away by the time I get backed out of my driveway.
12-03-2015, 07:06 AM | #5 |
Ok then. Take it to your dealer and have them check it out. The noise my car had would not go away. It was very noisy and after changing fluid at least 3 times and doing figure eights for hours the noise was still there. We had no choice but to have GM send us a complete rear axle assembly.
