03-19-2016, 10:51 AM | #1 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
2017 ZL1
Man... imagine that thing in silver with cf mods, murdered out... hmm.
2017 Chevrolet Camaro ZL1 Revealed! Packs 640 Supercharged Horsepower! Forget V-6s and four-cylinders, the ZL1 proves the V-8 muscle car is alive and well.
Official Photos and Info The new sixth-generation Chevrolet Camaro offers a four-cylinder engine for the first time since the 1980s, and its 1LE handling package is now available for the V-6 model. The Ford Mustang, too, has turned to a turbo four in response to tightening fuel-economy and emissions standards. But lest you think the days of howling, rip-roaring V-8 muscle cars are fading, the 2017 Chevrolet Camaro ZL1 is here to change your mind. A Z06 with a Back Seat? Debuting just ahead of the 2016 New York auto show, the newest version of the 10Best-winning Camaro is a no-holds-barred, supercharged V-8 beast. Of course, what you really want to know is how much muscle it’s packing. The answer is 640 horsepower and 640 lb-ft of torque, coming from General Motors’ LT4 supercharged 6.2-liter V-8 engine also found in the Corvette Z06. While the ZL1’s numbers fall 10 horsepower and 10 lb-ft short of the hottest Corvette’s, those figures still represent a whopping 60 horsepower and 84 lb-ft more than the last Camaro ZL1’s 580-hp 6.2-liter supercharged LSA powerplant. The latest ZL1 also weighs 200 pounds less than its predecessor, according to Chevrolet, thanks to the Camaro lineup’s move to GM’s lithe Alpha platform that’s shared with the Cadillac ATS and CTS. This improved power-to-weight ratio should make for blistering acceleration times. The last Camaro ZL1 we tested in 2014 hit the 60-mph mark in 4.1 seconds and ran the quarter-mile in 12.4. The 455-hp SS version of the new sixth-generation car trumped those numbers with a 3.9-second zero-to-60-mph run and a 12.3-second quarter-mile time. So, yeah, the ZL1 will be hellaciously quick. Six Speeds—or Ten! The ZL1 comes standard with a six-speed manual with active rev-matching capability, as you’d expect. But the big surprise is that the ZL1 will be the first GM product to offer the new 10-speed automatic transmission. This gearbox, developed in conjunction with crosstown rival Ford, has a 7.39 overall ratio spread, and Chevy says that the smaller ratio gaps between gears help optimize gear selection for acceleration and when exiting corners. Paddle shifters come standard. During a brief ride-along in a prototype ZL1 automatic, we were especially impressed with the 10-speed’s quick, crisp shifts. This new transmission will also be installed in seven additional models by 2018—we’d guess that the Corvette Z06 and the LT4-powered Cadillac CTS-V might be the next recipients. Although the ZL1’s horsepower and torque numbers seem strategically designed so as to not upstage the Corvette Z06, the Camaro team took more liberties with the chassis setup. Nearly all of the Z06’s best components are present in the ZL1, from the magnetorheological dampers to an electronically controlled limited-slip differential to GM’s impressive Performance Traction Management system. Standard 20-inch wheels are wrapped with Goodyear Eagle F1 Supercar tires in staggered sizes of 285/30 up front and 305/30 at the rear. The Camaro ZL1’s Brembo brake rotors, although not carbon-ceramic, are humongous 15.4-inch two-piece serving platters (Chevy has not yet shared information on the rear brakes). Those front rotors are actually larger than the standard Z06 units, and they’re only 0.1 inch smaller than the carbon-ceramic rotors offered with the Z06’s upgraded Z07 performance package. Chevy also throws some shade at the Ford Mustang Shelby GT350 and its harder-core GT350R variant by saying that the Camaro ZL1 is prepared for track duty without any optional add-ons, as it comes standard with 11 heat exchangers for proper powertrain cooling. Form and Function Visually, the 2017 Camaro ZL1 looks meaner than any sixth-gen Camaro we’ve seen so far. It’s not all for show, either, as the front splitter, rocker-panel extensions, and rear wing all are designed to improve the car’s aerodynamics for better high-speed stability. Helping with engine cooling, the hollowed-out Chevrolet “flowtie” badge makes its way onto the ZL1 after first appearing on the previous-generation Z/28. A new hood with the requisite power bulge incorporates a heat extractor, and the reworked lower grille maximizes airflow. The racy theme continues inside, with the standard Recaro seats featuring ZL1 badges and red stitching. The seatbelts also are red, and the flat-bottom steering wheel and shift knob are trimmed in microsuede. Track rats will appreciate the availability of GM’s Performance Data Recorder, which comes with a built-in camera and a GPS receiver that allows for location-based track maps. Look for the 2017 Camaro ZL1 to carry a starting price upwards of $60,000 when it goes on sale in late 2016. The ZL1 is significantly more powerful than the 526-hp Mustang Shelby GT350, while the 707-hp Dodge Challenger Hellcat has the Camaro beat in horsepower but has less-specialized chassis componentry. We’re certainly excited to see how the ZL1 stacks up when we get behind the wheel, so stay tuned. http://www.caranddriver.com/news/201...-and-info-news |
03-19-2016, 10:54 AM | #2 |
Still looks like a Mustang.
03-19-2016, 10:54 AM | #3 |
KaBoom1701
Impressive for sure.
The pricing that Chevy sets will be interesting. If they keep it in the low 60's then I think they have a hit on their hands. I'm betting this thing will run 72k with all the options. We will see...
Mods:
03-19-2016, 10:56 AM | #4 | |
$56,500 Listed MSRP is for a 2015 Chevrolet Camaro 2dr Cpe ZL1 base trim with no options. Includes destination fee. Does not include sales tax. Change Trim
$846/mo* This number is based on a 60-month, 0% APR loan. Assumes ZIP code of 90210 and and entered credit score of 800 or higher. Does not include sales tax. Loan payments will vary depending on options, vehicle availability, dealer participation, lender participation and terms, and credit score, all of which may vary from the assumptions above. The payment listed is not a guarantee or offer, only an estimate. Promotional interest rate used for monthly loan payment calculation valid 3/1/2016 - 3/31/2016. |
03-19-2016, 11:14 AM | #5 |
Envy
Drives: 2011 SGM 2SS/RS - Black hood/hockey Join Date: Aug 2011
Nah, dealers will be marking them up to 75k for sure.
03-19-2016, 11:16 AM | #6 |
CamaroFans.com
Not the dealers I know. You don't have to buy from your local dealer if they have a markup. Others can ship direct from the factory at MSRP.
03-19-2016, 11:23 AM | #7 |
KaBoom1701
Where's Becky when you need her? lol
She'll give us the best price.
Mods:
03-19-2016, 11:38 AM | #8 |
Drives: 2012 2SS LS3 Join Date: Jun 2012
Being one of the naysayers on the Camaro 6, this probably has changed my tune a bit. I still don't really like the looks of the SS and lower models, but there's just something about that front bumper and lower grille on the ZL1 that looks really good. I like those wheels too.
I am curious to see SRT's answer in the next couple years, with the HP numbers of competitors creeping ever so slightly closer to that 707 mark of the mighty Hellcat. |
03-19-2016, 12:12 PM | #9 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
03-19-2016, 12:21 PM | #10 | |
CamaroFans.com
http://www.camaro5.com/forums/showthread.php?t=412378 |
03-19-2016, 02:11 PM | #11 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
Wheels look good.
03-19-2016, 02:17 PM | #12 |
I'm interested to see the 1/4 mile times in that 10 spd auto! I am hoping it outruns the Hellcat in the 1/4 with the less power! Also considering they have built this ZL1 for the autocross I wonder if Chevy is gonna have a Z/28 at all in the 6th gen, or make the Z/28 more of a drag car.
03-19-2016, 02:28 PM | #13 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
Z/28 will not be the hero drag car.....never was..never will be...
Swift....Silent....Deadly
03-19-2016, 02:45 PM | #14 |
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jul 2014
