05-08-2019, 05:43 PM | #1 |
Drives: 2011 2SS/RS Join Date: May 2014
High Transmission Temps
So about 2 years ago I got my cam, heads, stall put on the car and initially didn't have an aftermarket tranny cooler, so I got a custom one done from a local transmission shop. Seemed to work great for the first year, highest temps were about 180-190 max. So about a year ago I noticed my temps getting higher than normal and the transmission would go into a sort of limp mode and throw a CEL. I got the cooler checked out and everything was running fine, and was told because of the stall and the high heats, that driving around the city would cause the transmission to get too hot if I was out for too long. Now I brought the car out a little over 2 months ago and the transmission seems to heat up so quickly. I could let it sit all day, fire it up, then it'll hit 180 within 10-15 minutes of driving. Could it be a problem with the cooler? Not sure what else it could be... any help or advice would be appreciated.
"Scarlett" the Black Widow
BTR Stage 4 Cam, FTI 3600 Stall Converter, GM 3.91 Gears, GPI Intake Mod V2, CAI Cold Air Intake, SLP 25% Underdrive Pulley, LS3 Conversion, PRC Ported/Polished Heads, Stainless Power Long Tubes w/off-road pipes, Borla Atak Cat-Back Exhaust, Tru Cool 40K 482rwhp/425rwtq, Built and tuned by Champion Motors |
05-08-2019, 05:52 PM | #2 |
'It's an experiment'
Cooler may not be big enough but, does it have a thermostat? 180° is not bad at all. Over 210° and I’d be looking for a bigger cooler. Stalls do create more heat and city driving does not help temps. What are your temps while highway driving?
With what I have, I road race in summer heat and it stays < 180°. I have the trucool 40k and it works... City driving i might see 160° in the summer - in Texas. Highway driving 150s°. I have a 6L90 Converter in my 6L80 so stall is factory — keep that in mind. -Don
747 RWHP 794 RWTQ
05-08-2019, 06:04 PM | #3 | |
05-08-2019, 07:31 PM | #4 |
Occasional times around 210° wont be bad at all. Constantly over that and you change fluid more often.
I raced mine before the bigger cooler, got it over 250° at times. When we rebuilt it, it looked great — the 35R showed a bit of heat but that was it. -Don
747 RWHP 794 RWTQ
05-08-2019, 07:36 PM | #5 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
I 2nd Hammdo's comments, 180F isn't bad, especially if you're running a stall converter, but getting hot enough for limp mode is a concern. Also I've found that the factory trans temp aren't precise (on any car I've ever owned). I'm more comfortable pulling temps from PCM data. What source are you using for your temp reading?
I'm running cam, heads, and 3800 stall with an ADM cooler and summer time averages are 160-175F. I did log 179-180F after 5 back to back 1/4 mile runs in the heat.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
05-08-2019, 07:55 PM | #6 |
I had limp mode once racing at Eagles Canyon — too much torque registered. Stopped, turned off the car, turned ignition on, reset the dtc, restart, didn’t happen after that. Ambient was 40°. Strangest thing for it to happen at those temps. Trans was 150° when it happened too...
-Don
747 RWHP 794 RWTQ
05-08-2019, 07:57 PM | #7 | |
05-08-2019, 10:35 PM | #8 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
If temps are up, is it slipping?
I went with a fan cooled oil cooler. This: https://www.holley.com/products/cool...parts/FP820ERL And if anyone wants to copy the setup..... Brackets: https://www.holley.com/products/cool...s/parts/800ERL Did a Frostbit 40amp wiring harness. https://www.holley.com/products/cool...ys/parts/FB403 Oil cooler adapters https://www.holley.com/products/plum...ts/AT585106ERL Speed-Seal Hose End Hose Size -6 Nut Size 6 Material Stainless Adjustable Low Profile 90 https://www.holley.com/products/plum...arts/609096ERL Bowler -6an manifold https://www.bowlertransmissions.com/...ifold-6l80cma/ -6an Speed-Seal Hose End Hose Size -6 Nut Size 6 Material Stainless Straight https://www.holley.com/products/plum...arts/600196ERL Speed-Seal Hose End Hose Size -3 Nut Size 3 Material Stainless Adjustable Low Profile 45 https://www.holley.com/products/plum...arts/604593ERL Thread sealer https://www.holley.com/products/plum.../parts/D024ERL -6an line https://www.holley.com/products/plum...arts/620006ERL
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
05-09-2019, 04:51 PM | #9 |
Went to my local shop today and told me that the trans cooler that I'm running is more than likely too small for the set up that I'm running. He has a few modded trucks/cars in his shop and he highly recommended that i go with the Tru Cool 40K as that's what he runs in all his vehicles and says he has zero trans temp problems.
05-20-2019, 06:42 PM | #10 |
Update, Tru Cool 40K installed and I could not be happier. Temps are staying low, even driving 30 minutes in stop and go traffic in 33 Celsius/91 Fahrenheit didn't even hit 180. Found one for 115$, so I'd say money well spent. Highly recommended!
05-23-2019, 06:30 PM | #11 |
Trans temps are simular to engine temps. The cooler the trans fluid the better but if its under 200* most of the time your ok.
05-23-2019, 08:08 PM | #12 |
Have had the Tru Cool for almost a week now and the temps barely even hit 170.
