10-13-2021, 05:15 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Atf
The new transmission came with Valvoline synthetic ATF is that a good brand to use in the transmission?
10-13-2021, 05:39 PM | #2 |
I always had a bad shift flare on the 2-3 shift when using GM's DEXRON VI. So much so that I could predict when it would flare 3 out of 4 times.
A couple years back I switched to Valvoline MaxLife Synthetic ATF and noticed an immediate improvement. No more shift flares ever. I also run the widemouth truck filter 'upgrade' for added flow and change my fluid every year or 15k miles. Anyhow, my point is - I think Valvoline is a top notch fluid manufacturer, and if the trans builder is recommending it, I would likely continue to use it, or at least give it a try.
10-13-2021, 07:04 PM | #3 |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
Valvoline MaxLife Synthetic ATF, I used it in the 6L90 and when I switched to the 4L80.
My car Pounds pretty hard on the transmission I have had no problems, the last time I changed it looked new and temps always ran around 170 to 180. hope this helps.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
10-13-2021, 07:16 PM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
That’s what I am using now in mine and no complaints so far. One of the best in that price range.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
10-13-2021, 07:39 PM | #5 |
Alot of good reviews about it , so I'll give it a try.
10-14-2021, 08:51 AM | #6 |
Hmmmm interesting. I might have to try this ATF out and see if there is any difference in mine.
10-18-2021, 12:03 AM | #7 |
Could it have been that my transmission died at 174k miles from not changing the fluid at 100,000k regular maintenance but changed it at 150k ?
10-18-2021, 07:38 AM | #8 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Most transmission failures are due to heat. Old fluid loses viscosity and more heat is created from increased friction.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-18-2021, 03:48 PM | #9 |
Banned
Drives: 2010 LS Join Date: Feb 2021
I used the Valvoline ATF in my last pan drop and filter/fluid change.
10-18-2021, 05:19 PM | #10 |
Even though the factory says 100K if you plan on keeping the car I would do it every 30k with filter change. (Minimum)
10-21-2021, 12:42 AM | #11 |
Update
Got it installed , the shifting feels so smooth 11 miles on it as of now.
10-21-2021, 06:55 AM | #12 |
Awesome!!
