Old 09-26-2012, 08:33 PM   #1
Austinv16
Drives: 2000 ss camaro with ly6
Trying to make 500rwhp my set up
Tell me what you guys think it will make the mods are: ly6 6.0 with vvt delete and dod delete with milled .20 l92 heads ls3 intake long tubes comp cam adver duration 285/293 lift 621/624 prc double valve springs and slp lid car is a 6 speed I think with this setup it will be bout 430 to the wheels but not real sure
Austinv16 is offline   Reply With Quote
Old 09-26-2012, 08:38 PM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
That's a huge cam! Should put down some impressive numbers. Is the short block stock?
Juiced1 is offline   Reply With Quote
Old 09-26-2012, 08:49 PM   #3
Austinv16
Yes it's stock
Old 09-26-2012, 08:53 PM   #4
Austinv16
Last setup made 380 Rwhp was a lq4 stock bottom end with ms4 cam and 241 heads with ls1 intake and slp lid
Old 09-27-2012, 01:28 PM   #5
02SS#214
02SS#214's Avatar
Drives: 2002 Camaro NBM Hartop SS
Originally Posted by Juiced1 View Post
That's a huge cam!
He did put down that it is the advanced duration for that cam, ie. 230/234 .600”/.612”, advanced is 279/286
02SS#214 is offline   Reply With Quote
Old 09-27-2012, 01:35 PM   #6
02SS#214
02SS#214's Avatar
From the sounds of the setup, I would think in the 400's for rwhp. I don't see it making the 500's withought a power adder to that setup. What about the rest of the setup? You said it has a 6 speed, what type of clutch, is the 6 speed stock or built, aftermarket readend? It's not only what the engine is pushing, but how the power gets to the ground.
Old 09-27-2012, 02:39 PM   #7
Austinv16
It has ky clutch and 4.10 10 bolt that's all I know about the drivetrain really want to make 500 to the wheel before I put 150 shot or 200 on it also need to put a 9inch under it
Old 09-27-2012, 03:03 PM   #8
02SS#214
02SS#214's Avatar
This!
