01-28-2013, 01:53 PM | #1 |
Drives: 2022 Camaro ZL1 Convertible A10 Join Date: Aug 2012
Best motor oils to use in ZL1 ?
Does anybody know if Castrol Edge is a good oil for the ZL1 ?
http://www.castrol.com/castrol/secti...tentId=7081095 I would like to see a list of the top 5 motor oils to use in the ZL1 Thanks. |
01-28-2013, 02:04 PM | #2 |
THE RED ROCKER
Drives: 2013 ZL1 VR Join Date: Feb 2012
Dont use that one....I'm loyal to Mobil 1 for all of my hot rods I have had previously.
01-28-2013, 02:42 PM | #3 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Castrol full sysn exceeds M1, but after a hard break-in I would go with a premium like Amsoil. I shy away from RP.
01-28-2013, 02:46 PM | #4 |
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR, Join Date: Dec 2012
What oil does Chevrolet put in it?
01-28-2013, 02:48 PM | #5 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Mobil 1! I have used it in my last four vehicles both GM and Ford. |
01-28-2013, 02:49 PM | #6 |
Mobil 1....5 W 30 is what the dealer uses.
01-28-2013, 03:02 PM | #7 |
Drives: 2013 ZL1 Join Date: Nov 2012
+1 for amsoil. I wouldn't use Mobil 1 personally.
1974 Cadillac Coupe DeVille
2002 Camaro Z28 A4 | 10.80 @ 131 | 383ci, D1SC, 4L80E, 9" 2013 Camaro ZL1 A6 | 12.62 @ 113 | Stock *SOLD 2017 Lexus GS350F |
01-28-2013, 03:02 PM | #8 |
01-28-2013, 03:04 PM | #9 |
Drives: 2012 SS TRANSFORMER EDITION Join Date: Dec 2012
OIL
What about Royal Purple?
01-28-2013, 03:10 PM | #10 |
Drives: Camaro Join Date: Mar 2012
I use Castrol Edge that meets Dexos specifications and it works real fine. No need to use anything else.
01-28-2013, 03:11 PM | #11 |
Not for the rear diff. I used it and made my rear SUPER noisy. The GM rear diff product is best
01-28-2013, 03:22 PM | #12 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
When I had my 2011, it even stated use Mobil 1 on the oil filler cap, and that's what I used.
When I took my 2013 ZL1 in for it's first oil change, I just assumed it would use Mobil 1 by deafult as well. But when talikng with the service advisor, the dealer owner stopped by to tell the service advisor not to charge me for the oil change. Somewhere in the conversation , the subject of Mobil 1 came up and the service advisor told the owner that Mobil 1 would cost more? I told him I didn't care about the higher cost, I wanted them to make sure to use Mobil 1. |
01-28-2013, 03:29 PM | #13 | |
Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
Nothing wrong with Castrol Edge. As for the top five oils, that is a matter of opinion for the most part. They are pretty much all good quality oils. Just depends on what you want to do. If you are looking at extended drains then you want a synthetic like AMSOIL's Signature Series oil or Mobil 1's extended performance as well as Redline and Royal Purple. |
01-28-2013, 04:36 PM | #14 |
After much research I run AMSOIL's Signature Series
JRE 750 HP package
Rag Top Rob |
