11-18-2013, 09:07 PM | #1 |
Drives: 2011 2SS Synergy Green Join Date: Nov 2011
Minimum parts needed for ZL-1 conversion?
I need to get my front end converted finally. What can I get by with just to install it all?
Fascia Absorber Support Lower grille I was going to try to get the minimum parts and not get the bezels or fog lights just yet. Do I have to have the absorber, support etc etc to install it? |
11-18-2013, 10:39 PM | #2 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
yes you have to have the absorber! That will save your life if you ever get in a crash....So i Highly recommend it!
Those parts should do it but you will also need the hardware that holds the splitter on. |
11-19-2013, 10:11 AM | #3 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
I thought you could just modify the stock absorber and you'd be fine?
11-19-2013, 11:39 AM | #4 |
Drives: 2010 IOM Camaro Join Date: Aug 2012
I would just buy the entire piece and be done with it. Everything would come and wouldnt have to be placing later...If you cant do all at once then wait till you can
11-19-2013, 02:27 PM | #5 |
Drives: 2012 LT Camaro Join Date: Jul 2012
Lots of miscommunication on this as different people go different routes but you don't even need to do that, but there will be some minor setbacks.
11-19-2013, 04:31 PM | #6 |
What minor setbacks will there be?
11-19-2013, 06:11 PM | #7 |
Just order the set from Garys Customz and be done already. I had zero setbacks
11-19-2013, 07:08 PM | #8 |
Drives: Red 2010 Camaro 2SS L99 Join Date: Apr 2010
if your gonna do it i recommend you wait, buy everything at once and do it right.
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers Exhaust Clip: http://youtu.be/c_quv8eoVNQ |
11-20-2013, 07:26 AM | #9 |
