03-24-2014, 06:53 PM | #1 |
Drives: 2016 2SS Convertible Join Date: Oct 2011
Removed the camaro from winter storage
I just took the camaro out from winter storage and I notice the transmission light stayed on all day. Had on star run engine diagnostic and got the following error code:Engine control sytem detected miss fire Error P0300
Have anyone else seen this error? I am taking it to dealer in morning to see what they can tell me. Its been sitting since November till today. Hope its not nothing major thanks for any advice or help you guys and gals can provide. |
03-25-2014, 07:52 AM | #2 |
Drives: 2014 SS Join Date: Jan 2014
Check all the spark plug wires, coil pack, and O2 sensors. Could also be something with the fuel injectors, burned exhaust valve, or a stuck EGR valve.
If it had a number at the end of it like "P0303" it would mean a direct misfire with cylinder 3, but because it is all 0's could be a number of things.
2014 SS Stainless Works Headers w/ high flow cats, Stainless Works Retro Chambered Exhaust, Jannety Tune, Hurst short throw, APEX catch can, Tampa Tunning Throttle Body, APEX/Gen5 LED fogs, CAI Intake system, Diode Dynamics LED's, ACS T4 Splitter
03-25-2014, 11:47 AM | #3 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
Did you use stabil in the gas when you stored it??
USMC 1980-1990
My other toys are Harleys |
03-25-2014, 12:33 PM | #4 |
Choke on that causality!
Drives: 2010 2SS/RS Join Date: Sep 2009
First thing I would do is clear the code and see if it comes back. Might just be a hangover from its long winter nap. If you don't have a handheld tuner you can just disconnect the battery for a few minutes to clear it.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
03-25-2014, 04:53 PM | #5 |
No stabilizer use left it with about 11 gallons of gas daily start ups all winter long. I am taking it to dealer tomorrow to see what this maybe.
03-25-2014, 07:03 PM | #6 |
Drives: 2011 2LT RS IOM Convertible Join Date: Dec 2010
I had a CEL as well when I started it yesterday for the first time in 4 months. The Torque app tells me it's a cylinder misfire but it's running and driving normally. I think it's a hangover as well so I will just clear it and see if it returns. I did have a full tank, stabil, and a battery tender on it.
03-25-2014, 07:11 PM | #7 |
Drives: 2017 Camaro 1SS 1LE Hyper Blue Join Date: Mar 2013
You started it every day? Sorry, if the car is not coming up to full operating temp that leaves moisture in the system. Possible that you have some corrosion causing connectivity issues in an electrical connection if you were starting it all winter long and not driving it.
03-25-2014, 09:59 PM | #8 |
Drives: 2008 VW R32, 2011 Synergy Green 2SS Join Date: Jul 2010
Seriously, you started your car every day while in storage. That is probably the worst thing you could do to your car. It is so simple to put a car in winter storage. Put in stabil and fill the tank, hook up a battery tender, pump up the tires, cover the car and start counting the days till it comes out.
03-25-2014, 10:24 PM | #9 |
Drives: 2013 Camaro 2ssrs Blue Ray Join Date: Jan 2014
My son had this issue two times, same code with his supercharged GTP, and it ended up finding a misfire 250 times on cylinder 5, that plug was smoked, and we ended up changing the plug wires, coil module, and plugs, and it's fixed. That code is a difficult one to diagnose.
03-25-2014, 11:36 PM | #10 |
ya unless you are driving it let it be. bet its just bad gas. check your oil. from starting it it might have water in it.
03-26-2014, 07:14 AM | #11 |
USMC 1980-1990
You also might want to check your exhaust system. If you were starting it everyday you were building up a tremendous amount of condensation in your exhaust pipes and mufflers because you were not getting them hot enough to burn it off. The same goes for your motor, if you haven't yet, change your oil.
When I store my Harley's and my Camaro they get oil changes going in, battery tenders and don't get started till I am ready to start driving them again. Starting any vehicle in freezing weather and shutting it off without driving it to heat everything up is "severe duty" at it's finest.
USMC 1980-1990
My other toys are Harleys Last edited by MCSarge; 03-26-2014 at 11:03 AM. |
03-26-2014, 07:20 AM | #12 |
Call Me"Doc"
Drives: 2014 2SS/RS 1LE BLACK Join Date: Apr 2009
My money is on a fouled plug, possibly caused by condensation in the fuel system...
