Old 09-16-2014, 12:47 PM   #1
vandervortadam
Drives: 2010 Camaro 2ss black 21's
Best 4 ch. amp to replace ba system.
Looking for a good 4 ch. Amp to replace the factory ba amp. Any good suggestions?
vandervortadam is offline   Reply With Quote
Old 09-16-2014, 01:58 PM   #2
camarostar2010
Drives: 2011 SS
this question is too vague...but a good start is any mtx or fosgate amp. Trusted names...and with true rms power ratings. Don't cheap out.
camarostar2010 is offline   Reply With Quote
Old 09-16-2014, 02:41 PM   #3
beemansilverjet
Banned
Drives: 2012 camaro
I want to do the same thing but will the factory speakers handle the extra power
beemansilverjet is offline   Reply With Quote
Old 09-16-2014, 05:02 PM   #4
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
first get the ******** Fark kit, then chose a name brand amp, I have the Alpine PDR f50
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 09-16-2014, 06:11 PM   #5
vandervortadam
I already ordered the fark harnesses. I used to have xtant old school amps and I loved them. Wish I could find some of them again.
Old 09-16-2014, 07:04 PM   #6
Homesickderf
Drives: Fast
Do you have subs or just replaced the amp
Homesickderf is offline   Reply With Quote
Old 09-16-2014, 07:31 PM   #7
vandervortadam
Just the amp for now. This winter I am doing a fiberglass box and amp rack.
Old 09-16-2014, 10:13 PM   #8
Homesickderf
Drives: Fast
Did it stop the distortion
Old 09-19-2014, 07:21 AM   #9
foo.fighter
foo.fighter's Avatar
Drives: 2013 Camaro 2SS IOM M6
noob question.. when you replace the factory amp with an aftermarket can you attach subs to it? or do you still need a second amp for the subs. This is using the fark kit for the ba system.
2013 2SS IOM LS3
Performance: NPP Exhaust, Solo Performance Hi-Flow Cats, k&n Air Intake, Doug Thorley Shorty Headers
Cosmetic: Diablo Angel Staggered 22", 3D Carbon Fenders (need to install) Eagle Eyes HIDs, Fog Light HIDs
foo.fighter is offline   Reply With Quote
Old 09-19-2014, 07:23 AM   #10
xinfamousxi
Drives: Camaro 1SS 1LE
This
xinfamousxi is offline   Reply With Quote
Old 09-19-2014, 08:09 AM   #11
tarik1985
tarik1985's Avatar
Drives: 2010 Camaro SS/RS
I was wondering the same thing .
tarik1985 is offline   Reply With Quote
Old 09-19-2014, 11:05 AM   #12
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
That depends on the amp you get. If it's a 4 channel then it'll be for the speakers. If u get a 5 channel, you can add a sub to it
Old 09-19-2014, 12:33 PM   #13
steelersgeek70
steelersgeek70's Avatar
Drives: 2011 Chevy Camaro 2SS/RS
I bought the Soundstream Picasso Nano PN5.640D from Crutchfield for $210.
Highlights:
  • 5-channel car amplifier
  • 60 watts RMS x 4 at + 200 watts RMS x 1 at 4 ohms
  • 80 watts RMS x 4 at + 350 watts RMS x 1 at 2 ohms
  • 160 watts RMS x 2 bridged at 4 ohms + 350 watts RMS x 1 at 2 ohms
  • separate variable high-pass filters on front and rear channels (35-350 Hz, 12 dB/octave)
  • variable low-pass filter on subwoofer channel (30-250 Hz, 12 dB/octave)
  • variable bass boost on sub channel (0-12 dB at 45 Hz)
  • Class D amp technology and MOSFET power supply
  • preamp and speaker-level inputs (RCA and bare wire input harnesses included)
  • wired remote sub level control included
  • 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
  • fuse rating: 40A x 1
  • 12"W x 1-3/4"H x 4-7/8"D
steelersgeek70 is offline   Reply With Quote
Old 09-19-2014, 01:41 PM   #14
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
You'd need to get an amp that has the additional channels for a subwoofer output.
There are a few out there.
I ran a second amplifier for the subwoofer (mono amp).
I used the FARK kit and replaced the factory amp with the JL XD 400 amplifier and I have a single 12" woofer running on a Kicker 400 watt mono amp. So I am running 100x4 and a 400 x 1
I used the pass through RCA jacks on the JL amplifier for the signal to the subwoofer amplifier and ran two sets of power and ground wires.
There are options for amps with 5 channels (4 for main speakers and one subwoofer channel) if you only wish to run one amplifier.
Certainly this can be done.
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
