04-10-2015, 01:27 AM | #1 |
Drives: Black 2ss Join Date: Jul 2011
Had a little incident today
I was cruising around 650 pm. The time of day where the sun makes the roadway not 100 percent visible.
I happen to run over an object! I immediately pulled over, my front right tire showed 21 psi, then 1 as I came to a stop. I had a flat front right tire, and my splitter has about a foot size piece broken off, and the front valence pulled off a bit from the front end. I called a friend to come pick me up to go get my other car, then I went to get my stock front tire. He drove me by where I hit the object. It happened to be a vise, like a big metal vise from a shop, just lying there in the road! The hole is in my sidewall, the tire has 765 miles on it. But I couldn't be more thankful! My brand new mr28 wheel was unharmed, its just a hole in the sidewall, I can replace the tire, I can fix the fender myself, and the splitter was just the 140 dollar ebay special slp splitter. Im thankful it was close to home where I could easily have a friend pick me up and put the old tire on. Im thankful I was on a road I could easily pull off and not cause more harm to myself or other traffic. Could have been a lot worse fellas. |
04-10-2015, 01:56 AM | #2 |
Drives: 2012 2SS Join Date: Jan 2015
I bet that would have broken the control arm off a lesser car! Did you at least keep the vise? Three guesses where It came from...
04-10-2015, 02:01 AM | #3 |
Drives: '14 Red 2SS/RS/LS3 Join Date: Dec 2013
Sorry to hear about the damage to your car, but yeah, it could have been worse. It sounds like you had a good contingency plan in place - "for just such an emergency."
2014 Red Hot 2SS/RS/M6/NPP/Shifter/Nav/Roof/SilverRallyStripes/Airaid intake/GM StrutTowerBrace/50%-35%tint
04-10-2015, 04:06 AM | #4 |
that sucks. hope you kept the vise though. If its anything like the one in the picture above they are nice to have.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
04-10-2015, 05:28 AM | #5 |
WOW I wish I had your kind of attitude, if it were me I would be pissed off!!!!
04-10-2015, 05:54 AM | #6 |
Drives: 2011 IOM 2SS/RS M6 Convertible Join Date: Feb 2014
I hope ya brought the vise home with ya, might be worth more than the damage to the car, good ones are expensive.
04-10-2015, 07:52 AM | #7 |
Drives: 2010 2SS LS3 Join Date: Mar 2015
Accidents happen! It could be worse. As long as no one gets hurt, a vehicle is only a piece of metal. I am glad you are safe and sound. Regards
04-10-2015, 07:56 AM | #8 |
Drives: Black 14 2SS/1LE/RS 14 Tundra Join Date: Dec 2013
04-10-2015, 07:58 AM | #9 |
Drives: 2014 Chevy Camaro SS Join Date: Oct 2014
Man.. that really stinks. But you handled it well and we're lucky in a few regards. I am not sure I could have handled it that well. Post some before and after shots so we can see it.
Number of people killed by wolves last year... Zero
Number of people killed retrieving change from a Vending Machine.. Six |
04-10-2015, 08:00 AM | #10 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Check under the car also for any paint damage, you don't want anything scraped through to bare metal and start rusting. But from your description it may not have hit anything under the car, just to be safe I would put it on a lift and check it out.
I hit an entire wheel and tire assembly on the interstate one early morning while it was still dark. Just over the top of a hill I hit it dead center in my 66 Corvair. It launched me up over it and broke the front air dam and tore loose the gas gauge wire but that was all it did. Glad you are ok and hope you get your car fixed soon.
The Bird is the word! |
04-10-2015, 08:04 AM | #11 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Glad you're okay... cars can be replaced, parts even easier.
Had my lower deflector (rubber piece underneath the front end) sliced clean off a few weeks ago due to road debri. Sounded rough underneath and it was dark so I didn't see it coming. I consider myself lucky also. |
04-10-2015, 08:08 AM | #12 |
Drives: 2015 Red Rock Camaro 1LT RS Join Date: Feb 2015
Send it for DNA testing and sue the dumba$$. Jk
Ian B |
04-10-2015, 08:13 AM | #13 | |
Lets roll...
Drives: 14' Join Date: Jun 2014
OP, you have a great perspective / attitude. Props to you good Sir.
04-10-2015, 08:40 AM | #14 |
You took it well. I'd be pissed if that happened to me. Hope everything gets fixed soon if it's not already.
With great power comes with responsibility. However with great horsepower comes a hell of a lot of speeding tickets.
