Old 04-13-2015, 12:58 AM   #1
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
10.5 (315) rubbing what size to fix?
running a 10.5 wheel and even with nitto invo 315 (supposedly are running less wide the all others) I get rubbing on big bumps. I want to smaller size but what should i run?
revived is offline   Reply With Quote
Old 04-13-2015, 01:17 AM   #2
forklord
forklord's Avatar
Drives: 2010 2SS
i think you may be limited by the rim offset and your drop....whats the offset and is it front or rear thats rubbing?
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 04-13-2015, 03:32 AM   #3
revived
Vrrrm.
revived's Avatar
dont know offset how can i measure it
Old 04-14-2015, 10:00 PM   #4
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
On the rear a 35 offset with a 10" rim works fine. So does a 10.5" rim
VR Baron is offline   Reply With Quote
Old 04-15-2015, 10:04 AM   #5
revived
Vrrrm.
revived's Avatar
You mean a 35 rear offset will fit a nitto invo 315 or a Michelin PSS 315? PSS are quite a bit wider then invo.
My 10.5 is fitting just rubs on big bumps so i'd like to either measure my offset then shave it or buy a 305 tire thats about .3-.5 less of a width. so it clears.
Old 04-15-2015, 10:06 AM   #6
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Why don't you try running a 3mm spacer on the rear, it might give you the extra clearance you need, as others have pointed out, the wheel offset is the issue.
So Cal Camaro is offline   Reply With Quote
Old 04-15-2015, 10:09 AM   #7
revived
Vrrrm.
revived's Avatar
I'm well aware of the issue being the tire offset i dont think you understand my question regarding tire size.
A spacer would make them stick out past the fenders.
Old 04-15-2015, 10:27 AM   #8
revived
Vrrrm.
revived's Avatar
http://i59.tinypic.com/289ilcn.jpg
As you can see the tire has a bulge i dont know why but when i measured the rear rims they where 10.5. The nitto invo is not (way to wide) just barely it actually clears no problem but oncei hit a big bump i hear it rub and the tire had a cut in the bulged area from hitting the innder fender.
1. who has a tire that runs about .3-.5 skinnier? nitto invo says there 315 is 12.4 wide?
or
2. roll fenders
or
3. figure out offset and shave the mounting surface to clear free up some room.
Old 04-15-2015, 10:44 AM   #9
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
I run a 11 inch wheel with 315 nitto tires lowered no issues.
Trob85 is offline   Reply With Quote
Old 04-15-2015, 10:47 AM   #10
So Cal Camaro
So Cal Race Team
Drives: 2013 Camaro
If 3mm makes that big a difference, you're the dumbass for buying wheels with the wrong offset.
Old 04-15-2015, 01:17 PM   #11
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Based on everything you have said I think you need to run a more narrow tire(305), or buy new wheels.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-15-2015, 01:20 PM   #12
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Hence his numerous requests for a tire brand/size that is not as wide.
JimE is offline   Reply With Quote
Old 04-15-2015, 01:32 PM   #13
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
You never stated the aspect ratio or rim size?
Old 04-15-2015, 01:35 PM   #14
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
HAHA.....so true. At first I thought he wanted to stick with a 315, but a skinnier one than he has already tried.
