06-22-2015, 09:09 AM | #1 |
Drives: 2014 SS/RS M6 Join Date: Apr 2015
Boiling at 220 degrees
Coolant boiling at 220 degrees, it runs at 190-205normally. But when I turn the car off and the temp rises to 220-225. That is when I hear boiling. Is there any fixes for this before I take my car in? Only mod is high flow cats, no tune.
06-22-2015, 09:34 AM | #2 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
I would think a leak in the system has occurred, and check for that or a weak cap.
06-22-2015, 09:50 AM | #3 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
If it truly is afterboil, a friend just had a problem with his car. Check the cap. Afterboil means the system isn't getting up to proper pressure.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
06-22-2015, 10:26 AM | #4 | |
Drives: 2014 Ford Mustang GT Premium Join Date: Jul 2014
Check for leaks in the hoses as well. |
06-22-2015, 10:51 AM | #5 |
06-22-2015, 05:26 PM | #6 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
as a general FYI, a 15psi system will raise the boiling temp to just about 247*F (when working correctly).
