12-04-2017, 01:16 PM | #1 |
Drives: 2016 SS Red Hot Join Date: Mar 2016
Dealer Murdered My Rear Differential!!!
I took my 2016 SS in to the local dealer to have the rear differential fluid replaced after taking it to the track (as recommended in the owner's manual). They replaced the fluid and the next day there was a horrible rubbing/groaning noise coming from the back end. I took it back to the dealer and they realized they put in the correct fluid, but did not add the lubricant additive that they were supposed to. They put in the additive and it helped a little. I took it back a third time and they swapped out the rear diff fluid with extra lubricant this time. It was better, but still not right. Still groaning and the rear tires chattering in tight turns. It is now at the dealer getting a whole new rear differential put in. Really? is it that hard to put the correct fluid in the first time? Worst of all, the service manager told me he will not refund the money that I originally paid to have the rear diff fluid exchanged!!! :
12-04-2017, 01:30 PM | #2 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
It is my understanding that the current GM diff fluid now contains the additive. Sorry you're having the problem.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
12-04-2017, 01:33 PM | #3 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
Another horror story to add to the list for me and why my cars do not go to the dealer unless is is something catastrophic or so obviously wrong. I do all of my own maintenance period.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
12-04-2017, 01:44 PM | #4 | |
Drives: 2016 Camaro 2SS Join Date: May 2017
IG: @manat.0
12-04-2017, 02:15 PM | #5 | |
Drives: 2017 Camaro SS M6 Join Date: Apr 2017
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
12-04-2017, 02:20 PM | #6 |
I think it is a tire issue, because when I had 275s I did not experience anything like this. Will be getting an alignment done soon, thanks man
IG: @manat.0
12-04-2017, 02:23 PM | #7 |
Drives: Fifty 2SS Vert Join Date: Dec 2009
Every muscle car I've owned with a Posi-trac differential had a slight REAR wheel chatter when turning sharp at low speed.
12-05-2017, 07:00 AM | #9 | |
Drives: 2017 Camaro 2SS Join Date: Dec 2016
I had my car aligned following lowering my car and put it in perfect spec. Two days later my wheels showed up. put them on and realigned. Alignment shop showed the car was slightly out of alignment. |
12-05-2017, 07:11 AM | #10 |
Banned
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Tell him to either refund your money or you'll give them all zeroes on the service survey you will receive in the mail. They take that stuff seriously.
And if he doesn't refund you, give them all zeroes. |
12-05-2017, 08:00 AM | #11 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Since the correct fluid already has the lube added they put the wrong fluid in.
12-05-2017, 09:43 AM | #12 |
________/\_
12-05-2017, 10:54 AM | #13 |
Drives: 2017 GRT 2SS/RS M6 Vert Join Date: Jan 2014
And the dealer is making good by replacing the differential. I assume they are eating the cost...so why try and stiff them for the cost of the initial visit?
If it were more fun, it would be illegal!
12-05-2017, 11:03 AM | #14 |
Drives: 17 SS 1LE | 07 S2K Join Date: Sep 2017
Dealers don't "eat the cost" of warranty work, the manufacturer reimburses them for time and materials. That's how they MAKE money.
The fact that they completely screwed up the service which caused multiple repeat visits, multiple days without the car, and customer frustration is *exactly why* they should be refunding the money spent for the fluid swap. Oh, and the fact that they obviously did it wrong and therefore shouldn't charge in the first place. That's pretty obvious to me, they wouldn't keep my money. |
