06-06-2019, 01:31 PM | #1 |
SS FASTER THAN 1LE?
You'll have to excuse me, I'm a NOOB. I've seen it in many different places that the SS is faster in a straight line than the 1LE. Is this true? If so, why? Just curious.
18 NIGHTFALL GRAY 1LE, "THE MISTRESS"
IG: @HOST1LE_SS |
06-06-2019, 01:33 PM | #2 |
Drives: 2016 1ss camaro Join Date: Feb 2016
same motor same tranny only big difference is bigger brakes and elsd on 1le times in a straight line should be pretty close if not the same
06-06-2019, 01:35 PM | #3 |
Drives: 18 1SS/1LE Join Date: Jun 2018
"Ive seen it in many different places"...provides zero references.
06-06-2019, 01:35 PM | #4 |
That was my thought as well. Is there a weight difference?
IG: @HOST1LE_SS |
06-06-2019, 01:36 PM | #5 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
However you are talking about a negligible difference. The slight weight penalty is 100X made up for in its track and handling increase capabilities. Mostly from increased ultimate grip and MRC that is specially tuned on the 1LE.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
06-06-2019, 01:36 PM | #6 |
Vinnay, mostly YouTube videos, honestly.
IG: @HOST1LE_SS |
06-06-2019, 01:37 PM | #7 | |
Drives: Black Join Date: Jan 2017
until recently the 1le was only available with a manual, so most tests with the 1le were with a manual, and many test with an SS are automatic. If both have the same trans, they should be near identical, if anything a slight edge to the 1le because of the tires. Any variation in times is more likely due to differences in driver. |
06-06-2019, 01:41 PM | #8 |
Banned
Drives: None at the moment Join Date: May 2018
Without any "proof", I would guess the A8 SS is faster in a straight line than the 1LE. Thats about it though. The 1LE has the eLSD, and that might help get it off the line faster in an m6 vs m6 race. But the auto will edge it out no doubt even with the best manual driver in the 1LE.
06-06-2019, 01:54 PM | #9 |
Drives: 2006 Pontiac GTO Join Date: Jul 2015
Negligible differences, not something worth debating imo.
- Extra weight (depending on the equipment package of the SS of course) - more rolling resistance with the beefier wheels/tires |
06-06-2019, 01:57 PM | #10 |
Drives: SS 1LE Join Date: Oct 2017
Actually, when I was looking into getting one of these cars, the magazine tests I read (motortrend, car&driver, etc- I must have read them all) actually said the 1LE was faster in a straight and attributed that to the tires and differential.
06-06-2019, 01:59 PM | #11 |
I'm sure that if there is a difference, it is negligible. Thanks for the responses, guys.
IG: @HOST1LE_SS |
06-06-2019, 02:22 PM | #12 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
I won the stock V8 class in my 1LE at Camaro Fest last year. Came in 2nd the year before.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
06-06-2019, 03:45 PM | #13 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
Id say that is a valid statement, but youre talking 1/10th of a second due to the downforce of the 1le if even that in a 1/4 mile i.e., 12.4 vs 12.5.
Current:
2018 1SS 1LE - stock Past: 2008 C6 - heads/cam/boltons 2005 GTO - cam/boltons |
06-06-2019, 04:19 PM | #14 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
What you're hearing might be the difference between a 1LE with a manual vs a SS with an auto. The auto transmission is faster in a straight line.
It's not the 1LE package, it's the difference between transmissions.
