08-21-2019, 03:05 AM | #1 |
what is needed to run a ZL1 low side intank pump?
tune change? running E90 and planing on cam and heads in the future.
08-21-2019, 08:03 AM | #2 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I don't think anything is needed. I swapped mine out in preparation for going FI. At the time I was tuned, running E85. Also had CAI and headers . Car didn't seem to notice the change i.e. no CELs
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned |
08-22-2019, 12:45 AM | #3 |
why is it everywhere i look for a ZL1 pump they list the same pump for the 17 SS and ZL1.
08-22-2019, 06:52 AM | #4 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I did AC Delco M100183 for the LT4 in-tank pump. Hopefully I did the right one...lol
You’ll also want to change the desired fuel pressure in the FSCM. Will cost you one credit with HP Tuners.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
08-22-2019, 08:40 AM | #5 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
1LE SS and ZL1 have the same pump. There are definitely 2 different part numbers available. Look up Wildhammer or SkidMark garage. That being said I doubt you will need to touch the stock fuel system NA unless going Max effort 600whp+.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
08-22-2019, 12:16 PM | #6 |
im almost maxed out with what i have now on E90. plans are cam and heads. ill get the 38% fuel lobe so that will probably keep it safe on E but i was thinking since i have the drive shaft out might as well pull the tank. the M100183 pump is only $124 https://www.rockauto.com/en/parts/ac...assembly,10147
08-22-2019, 01:47 PM | #7 |
Drives: 6th gen Join Date: Aug 2013
King how lean do you go for a stock lt1 fuel system support anything but fbo. I’m fbo as far as the fuel systems concerned on e70 and 5.5ms on the injectors even at a .89 lambda
08-22-2019, 02:12 PM | #8 | ||
38% cam will give you another 100+ whp of fuel headroom on the highside. E90 is probably eating up some fuel headroom. Quote:
5.5 isn't bad. Bigger fuel lobe will net will raise the ceiling quite a bit on the high side. Pray has several heads/can cars running E on stock fuel system. AFR isn't the only thing to consider either. EOIT plays a big part in extending the fuel injectors capacity.
2016 NFG 1SS A8
08-23-2019, 11:54 AM | #9 |
E90 is what we have at the pump and i dont want to bother mixing. So basically unless I go FI i dont need the pump?. im 4ms on 93. I havent run a log on E90 but i believe my tuner said I was at 4.5ms and he doesnt like going over 5.
08-23-2019, 12:09 PM | #10 | |
Any benefit to upgrade the low side on a fbo car? |
08-23-2019, 04:59 PM | #11 |
Drives: SS 6 speed of course Join Date: Jan 2016
You need to check the lowside fuel pressure 60 to70 is what my tuner likes. Anyway other than the convertible needing a bunch of other stuff. You just need really small hands to plug the stuff in... probably time to be nice to the wife.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
08-23-2019, 06:40 PM | #12 |
No wife and hands are catchers gloves.
08-23-2019, 08:27 PM | #13 |
Um, find the smallest guy friend. I'm not kidding it was really really tight.
08-23-2019, 08:41 PM | #14 |
is it illegal if i pay a hooker to do it.
