Old 01-22-2021, 08:44 AM   #1
mikes red 2015
Drives: 2015 Camaro Rs 1LE, 1967 RS Camaro,
New Clutch
Good mornng, any oppinions on Monsters LT1-S. Looking to possibly useing that to replace the prematurley worn out in my car. Let me know Thanks Mike
mikes red 2015 is offline   Reply With Quote
Old 01-22-2021, 08:57 AM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
In for opinions, this is the clutch im seriously considering for my car when needed.
Sent from my SM-G973U using Tapatalk
Firefighter is offline   Reply With Quote
Old 01-22-2021, 10:24 AM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
I've had several triples and this clutch is awesome if under 1000hp. Really easy to drive in traffic or parking lot. Holds the power well. First two were quiet, my current one is a little noisy when depressing the pedal. I don't recall any of them chattering.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 01-22-2021, 10:54 AM   #4
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I have it. It's great. Drives and feels just like stock ZL1 clutch. Minor (barely audible) gear rattle below 1500rpm, but nothing crazy.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 01-23-2021, 08:18 AM   #5
mikes red 2015
Thanks for the info, i am a little concerned about the reported clutch rattle. i dont see any manufacture that just have an upgraded single disk. i have not taken mine appart to figure out why the stock unit failed at 10,000 miles of not hard driving. Mike
Old 02-04-2021, 01:30 PM   #6
mikes red 2015
Does anyone have any luck with useing a single disk clutch? will it hold up? All i have on the car is a thottle body spacer and a cold air kit. Let me know thanks Mike
Old 02-06-2021, 09:07 PM   #7
bottletalk
Drives: 15 Camaro 2SS M6
https://www.camaro5.com/forums/showthread.php?t=314832
That's one reason.
Go with the the double/twin lt1s, check your throw out and replace that plastic crap with billet. Monster will install it for u on a new slave which u should get too if your unsure of the cause.
When did u get the car? Previous owner could have had a performance setup then returned it to stock without setting up the slave properly.
bottletalk is offline   Reply With Quote
Old 02-08-2021, 07:50 AM   #8
mikes red 2015
That's one reason.
I got it in 2015, it had 1500 miles on it.I dont think it had any mods done and removed. I am going to tear it apart to try and find out why i had a failure at 10,000 miles. It has not had a rough life. i would really like to find out the cause, Thanks for the input. Mike
Old 02-08-2021, 08:32 AM   #9
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
https://www.rangeracceleration.com/Clutch_Care.html
have you tried this yet? I have the LT1-S and it drives like stock...
make sure to get the speed bleeder when you do replace it, makes life a lot easier...
Good luck!
PEACE
Old 02-08-2021, 10:13 AM   #10
mikes red 2015
Good luck!
PEACE
Thanks for the feed back, i am looking at getting the whole package from monster, Clutch, flywheel, slave, bearing support and speed bleader
